esp-matter with Micropython
JayAhr
Postby JayAhr » Mon Mar 25, 2024 9:41 pm
Dear ESP community,
I have an existing Micropython (version 1.22.1.0, ESP-IDF 5.1.2) project running fine on an ESP32 WROVER. Now I'd like to add Matter to the project via esp-matter. Build setup is working. I can build the "light"-example just fine. To test the build chain from within Micropython, I added a file with the following content:
// Includes from the "light device" example.
#include <esp_matter.h>
#include <esp_matter_cluster.h>
#include <esp_matter_console.h>
#include <esp_matter_ota.h>
// Matter is C++ based, so functions need to be wrapped into extern "C"
extern "C" void matter_build_test()
    // Use something from Matter SDK to check build chain.
    node::config_t node_config;
and incorporated the contents of the "light"-example CMakeLists.txt into the Micropython CMakeLists, see below.
When I try to compile this, the following CMake error occurs:
CMake Error:
  Error evaluating generator expression:
    $<TARGET_FILE:__idf_mbedtls>
  Target "__idf_mbedtls" is not an executable or library.
What can I do to solve this? Thanks in advance for any help.
# Top-level cmake file for building MicroPython on ESP32.
cmake_minimum_required(VERSION 3.12)
### For matter (begin)
    if(NOT DEFINED ENV{ESP_MATTER_PATH})
        message(FATAL_ERROR "Please set ESP_MATTER_PATH to the path of esp-matter repo")
    endif(NOT DEFINED ENV{ESP_MATTER_PATH})
    # set(PROJECT_VER "1.0")
    # set(PROJECT_VER_NUMBER 1)
    set(ESP_MATTER_PATH $ENV{ESP_MATTER_PATH})
    set(MATTER_SDK_PATH ${ESP_MATTER_PATH}/connectedhomeip/connectedhomeip)
### For matter (end)
# Set the board if it's not already set.
if(NOT MICROPY_BOARD)
    set(MICROPY_BOARD ESP32_GENERIC)
endif()
# Set the board directory and check that it exists.
if(NOT MICROPY_BOARD_DIR)
    set(MICROPY_BOARD_DIR ${CMAKE_CURRENT_LIST_DIR}/boards/${MICROPY_BOARD})
endif()
if(NOT EXISTS ${MICROPY_BOARD_DIR}/mpconfigboard.cmake)
    message(FATAL_ERROR "Invalid MICROPY_BOARD specified: ${MICROPY_BOARD}")
endif()
# Define the output sdkconfig so it goes in the build directory.
set(SDKCONFIG ${CMAKE_BINARY_DIR}/sdkconfig)
# Save the manifest file set from the cmake command line.
set(MICROPY_USER_FROZEN_MANIFEST ${MICROPY_FROZEN_MANIFEST})
# Include board config; this is expected to set (among other options):
# - SDKCONFIG_DEFAULTS
# - IDF_TARGET
include(${MICROPY_BOARD_DIR}/mpconfigboard.cmake)
# Set the frozen manifest file. Note if MICROPY_FROZEN_MANIFEST is set from the cmake
# command line, then it will override the default and any manifest set by the board.
if (MICROPY_USER_FROZEN_MANIFEST)
    set(MICROPY_FROZEN_MANIFEST ${MICROPY_USER_FROZEN_MANIFEST})
elseif (NOT MICROPY_FROZEN_MANIFEST)
    set(MICROPY_FROZEN_MANIFEST ${CMAKE_CURRENT_LIST_DIR}/boards/manifest.py)
endif()
# Concatenate all sdkconfig files into a combined one for the IDF to use.
file(WRITE ${CMAKE_BINARY_DIR}/sdkconfig.combined.in "")
foreach(SDKCONFIG_DEFAULT ${SDKCONFIG_DEFAULTS})
    file(READ ${SDKCONFIG_DEFAULT} CONTENTS)
    file(APPEND ${CMAKE_BINARY_DIR}/sdkconfig.combined.in "${CONTENTS}")
endforeach()
configure_file(${CMAKE_BINARY_DIR}/sdkconfig.combined.in ${CMAKE_BINARY_DIR}/sdkconfig.combined COPYONLY)
set(SDKCONFIG_DEFAULTS ${CMAKE_BINARY_DIR}/sdkconfig.combined)
# Include main IDF cmake file.
# Set the location of the main component for the project (one per target).
list(APPEND EXTRA_COMPONENT_DIRS
    "${ESP_MATTER_PATH}/components"
    "${MATTER_SDK_PATH}/config/esp32/components"
    # main_${IDF_TARGET})
    main)
# Define the project.
project(micropython)
    # list(APPEND EXTRA_COMPONENT_DIRS
    #     "${ESP_MATTER_PATH}/components"
    #     "${MATTER_SDK_PATH}/config/esp32/components")
    idf_build_set_property(CXX_COMPILE_OPTIONS "-std=gnu++17;-Os;-DCHIP_HAVE_CONFIG_H" APPEND)
    idf_build_set_property(C_COMPILE_OPTIONS "-Os" APPEND)
    # For RISCV chips, project_include.cmake sets -Wno-format, but does not clear various
    # flags that depend on -Wformat
    idf_build_set_property(COMPILE_OPTIONS "-Wno-format-nonliteral;-Wno-format-security" APPEND)
Users browsing this forum: sc0ut_ and 237 guests
