xQueueSend
ryuhhh
xQueueSend
Postby ryuhhh » Thu Dec 22, 2016 10:10 am
Hi, I have a problem to use xQueueSend function.
Here is my code.
xQueueHandle hQueue1 = 0;
void Sender_Task(void *p)
    int i=0;
    while(1)
      printf("Send %i to receiver task\n", i);
      if (! xQueueSend(hQueue1, &i, 1000))
        printf("Failed to send to queue\n");
      i++;
      vTaskDelay(100);
void Receiver_Task(void *p)
    int rx_int = 0;
    while(1) {
      if (xQueueReceive(hQueue1, &rx_int, 1000))
        printf("Received %i\n", rx_int);
      else
        printf("Failed to receive data from queue\n");
void app_main()
    nvs_flash_init();
    hQueue = xQueueCreate(QUEUE_SIZE, sizeof(int));
    xTaskCreate(&Sender_Task, "sender_task", 2048, NULL, 5, NULL);
    xTaskCreate(&Receiver_Task, "receiver_task", 2048, NULL, 5, NULL);
and from uart, I received a message, "freertos/queue.c:721 [xQueueGenericSend] - assert failed"
And just after it, Guru Mediation error follows.
Is there anything mistake in my code?
Re: xQueueSend
Postby ESP_Sprite » Thu Dec 22, 2016 12:37 pm
That location asserts if the queue is NULL. Are you sure you copy-pasted all your code? Especially these contradict eachother:
