ESP32 Free Heap
Re: ESP32 Free Heap
Postby ESP_Sprite » Tue Dec 13, 2016 5:23 am
Fyi, from what I remember the amount of D-port RAM is 328K at maximum; the rest is IRAM, cache etc. We actually feed the free IRAM into the dynamic memory allocator as well; you can allocate it using pvPortMallocCaps(size, MALLOC_CAP_32BIT). (Or at least, you should be able to; something broke, I'm working on a MR to make this work again.)
We indeed will be working on minimizing esp-idf RAM usage at a certain point in time; for now, we think it's more important to get all features in first.
kolban
Re: ESP32 Free Heap
Postby kolban » Sun Dec 25, 2016 11:07 pm
I had failed to notice the following at the start of a boot log:
I (1080) heap_alloc_caps: Initializing. RAM available for dynamic allocation:
I (1081) heap_alloc_caps: At 3FFC2144 len 0001DEBC (119 KiB): DRAM
I (1083) heap_alloc_caps: At 3FFE8000 len 00018000 (96 KiB): D/IRAM
I (1092) heap_alloc_caps: At 4009C2A0 len 00003D60 (15 KiB): IRAM
I (1100) cpu_start: Pro cpu up.
This seems to say we have a current max of 119 + 96 + 15 = 230K.
Later ... following on from Mr Sprite's comment, I dug to see if I could find out how much IRAM might be available for allocation. On a fresh boot, I ran the following statement:
LOGD("Free IRAM: %d",  xPortGetFreeHeapSizeTagged(MALLOC_CAP_32BIT));
Result: Free IRAM: 15704
This matches the log statement prior. I am also led to believe that for RAM addressing, we have:
  • 256K - 0x3FFB 0000 - 0x3FFF 0000 - Data RAM
  • 128K - 0x4008 0000 - 0x400A 0000 - Instruction RAM
But I seem to be missing the last 128K to bring my total up to the 512K of RAM I think the ESP32 should have.
Re: ESP32 Free Heap
Postby ESP_Sprite » Mon Dec 26, 2016 1:46 am
In total, there's 516K of memory. Of these:
- 32K is used for flash cache on CPU0
- If enabled, 32K is used for flash cache on CPU1
- 8K+16K are used by the ROM
- If BT is enabled, 64K is used by BT ROM
Fyi, esp-idf/components/esp32/heap_alloc_caps.c gives a good overview; the regions struct array defines what memory is available, the start of heap_alloc_init disables regions that are reserved.
zizoalbert
Re: ESP32 Free Heap
Postby zizoalbert » Tue Jan 10, 2017 4:12 pm
I need for your help to understand the memory mapping in esp32.
it serves what this part of memory :
{ (uint8_t *)0x3FFE0000, 0x4000, 1, 0x400BC000}, //pool 9 blk 1
{ (uint8_t *)0x3FFE4000, 0x4000, 1, 0x400B8000}, //pool 9 blk 0
whats does it mean blk 0 ? blk1?
thank you
Re: ESP32 Free Heap
Postby ESP_Sprite » Wed Jan 11, 2017 1:31 am
It's a hardware detail; iirc some internal debugging stuff can use one of these. It's not really relevant for software, you can look at these as just two normal memory blocks.
zizoalbert
Re: ESP32 Free Heap
Postby zizoalbert » Thu Jan 12, 2017 8:39 am
Thank you for your help.
After reading a lot of document and looking in the code and on the INTERNET, I came to this conclusion :
RAM (512 KB) = IRAM (128 KB) + DRAM (384 KB)
*****DRAM*********************************************************************************************
---DRAM mapping------- (384 KB)
Bt stack (64K) (0x3FFB0000 - 0x3FFC0000) (can use it if BT is not activated)
Heap (0x3FFC0000- 0x3FFF0000)
MAC dump (0x3FFF0000-0x3FFF8000) (Can't write in it)
Memory trace (0x3FFF8000 + 64K) (Can writ in it if it's not activated)
- If we want know the available DRAM memory we can use this function : esp_get_free_heap_size()
-we can use it if we use : DRAM_ATTR
*** IRAM ************************************************************************************************
---IRAM mapping------ (128 KB)
Flash cache for PRO and APP cpu (0x40070000-0x40080000)
Stack (0x40080000-0x400A0000)
- To know the available IRAM memory we can use this function : xPortGetFreeHeapSizeTagged(MALLOC_CAP_32BIT))
- We can use it if we use : IRAM_ATTR
I want to know if my conclusion is right or it is wrong or it missing some things? Thank you
Re: ESP32 Free Heap
Postby ESP_Sprite » Thu Jan 12, 2017 12:45 pm
That is almost correct. Asking for the amount of MALLOC_CAP_32BIT will give you back all memory that can handle 32-bit aligned reads; because the DRAM can also do this you will also get this included. Also, part of the DRAM you mentioned actually can also be used as IRAM, if needed.
Users browsing this forum: Yahoo [Bot] and 1 guest
