Hi
i am trying to make all gpio are input and output in esp32 with eclipse IDE, GPIO 2,0,4,16,17,5,19,18,21,22,23,25,26,27 i can configure now, anyone please tell me how to use multiplexed pins as gpio only.
How to configure all gpio as input and output in esp32
Re: How to configure all gpio as input and output in esp32
Howdy amalamal,
To the best of my knowledge, calling gpio_pad_select_gpio() on any of the pins 0-39 makes them GPIOs. However, please realize that pins 34-39 can be used as input only while all the other pins can be used as input or output. Also note that the pins 20, 24, 28, 29, 30 and 31 are not exposed so there are a maximum of 34 pins available to us.
Hi Sir
Thanks for the suggestion, i tried like that with " gpio_pad_select_gpio()" function, except GPIO 32,33,6,7,8,11 are working, I tried of making those pins as input, the system is rebooting continuously, i am attaching my code, please find attachment.
- Make gpio as input_esp32.c.tar.gz
- (1.04 KiB) Downloaded 1479 times
Hi WiFive
As GPIO 6-11 is connected with flash , so can i use those pins as normal gpio or not ?
We are planning one application with esp32 which needs more gpios , so i need to confirm whether esp32 is suitable for it. Could you please confirm the status about gpio 6-11.
Amal
Amal
- martinayotte
No ! How the ESP would run without having access to the flash ...amalamal wrote: As GPIO 6-11 is connected with flash , so can i use those pins as normal gpio or not ?
If you need more GPIOs, why not use an I2C GPIO Expander, such MCP23017 ?
Thanks for your replay sir,
Now i am planning to connect an external flash in the same lines of internal flash(SD0,SD1,SD2,SD3,CLK) with another chip select, is it possible?
If it is possible , how i can disable the chip chip select pin of internal flash so i could enable my external flash and do read and write data.
Amal
Amal
At the moment, using the esp-idf drivers, you cannot use the lines for the internal SPI flash for anything else yet. We have plans to change this in the future, but we're not there yet.
Users browsing this forum: Pedro Hugo PSC and 140 guests
