i2s parallel only works with one dma descriptor
ESP_Angus
Re: i2s parallel only works with one dma descriptor
Postby ESP_Angus » Tue Dec 03, 2019 1:32 am
Baldhead wrote:
Mon Dec 02, 2019 4:41 am
I send the code via technical inquire. I can send via technical inquire again with the bugs that i encontered after send first time corrected.
Or i can send via private message maybe.
Hi Baldhead,
What Houwenxiang is asking for is a full project that can be compiled, flashed, run, and will show the problems. It's not possible to debug individual pieces of code by themselves, and the context is not always clear when you can't see everything.
A zip file could be attached to this thread. Or if you don't wish to post the project publically then sending a link to Houwenxiang via Private Message should be OK.
Angus
Baldhead
Postby Baldhead » Tue Dec 03, 2019 4:02 am
I sent a private message but apparently i can not attach no file extensions.
I will try a link.
Thank's.
Baldhead
Postby Baldhead » Tue Dec 03, 2019 4:25 am
I sent a private massage with a link to my full project.
Only the build folder which is too big i deleted.
Thank's.
