ESP32-WROOM hardware design for flashing
I have several time using microcontrollers. Now I'm starting with this module.
I need to make a PCB with this module but I coldn't find how I will flash the firmware on it. I reed that need to put IO0 to GND, then that only a pulse is enough.
Please, I need some help or where I can find that procedure.
Regards
Pablo
Regards
Pablo
Re: ESP32-WROOM hardware design for flashing
It's pretty simple: just after it comes out of reset, the ESP32 will look at IO0 and if it's grounded, it will boot into download (flashing) mode. The simplest implementation is two buttons: button 1 to ground IO0 and button 2 to ground EN. If you keep button 1 pressed while pressing and releasing button 2, the ESP32 is in download mode. There also are simple circuits that can do this automatically given your USB-to-serial converter has handshaking lines: check out e.g. the ESP32-DevkitC schematics for that.
Thank You. Then I will build my own USB converter with those buttons or the handshaking circuit, I don't want to leave that on board.
also needing help !
I really wish it was so simple, I am also struggling to get in and out of programming mode
is there any other documents available ?
Please and thankyou
David.
Please and thankyou
David.
...what is your exact issue, what do you require documentation on?
my problem is here, Thank you for looking.
viewtopic.php?f=12&t=20945
I would start here:
https://github.com/espressif/esptool/#e ... bootloader
and then read this:
https://github.com/espressif/esptool/wi ... l-Protocol
The datasheet has the electrical characteristics for the strapping sequence.
https://www.espressif.com/en/support/do ... -documents
and then read this:
I need to program the modules in production. I mean that is not easy the way to push a button, hold, then release, etc. If I will program thousand per day, that will be a caos....
Users browsing this forum: No registered users and 57 guests
