Page 2 of 2
Re: [Answered] What are the ADC input ranges?
Posted: Tue Jun 06, 2017 10:26 pm
by mnemonix
Sorry for the late respond, just seen your question today.
Attached is my LibreOffice Calc-sheet I hope you can use it.
Re: [Question] What are the ADC input ranges?
Posted: Tue Jun 13, 2017 4:05 pm
by sandeeptara
I am a newbie - How to read analog using arduino IDE ?
Posted: Wed Aug 30, 2017 3:25 am
by vseven
I purchased a NodeMCU ESP32-S to bring in some 0-10v analog inputs. I've converted them down to 0-3.3v but I've found the same issues as in this thread. Below about 0.2v there is nothing, above 3.1v same thing. Between 2.9 - 3.1 I get a lot of noise and bouncing even though the voltage coming in is stable. But beside all that I cannot get a linear line using 12-bit resolution. Has any progress been made on this?
Posted: Wed Sep 06, 2017 4:42 pm
by vseven
In case anyone following this is interested I did lots of testing:
https://esp32.com/viewtopic.php?f=19&t= ... 739#p13739
Posted: Tue Dec 05, 2017 6:48 am
by ParthRathod
ESP32 has 12bit of ADC as per datasheet. so it can measure the change of 12mV on ADC line
I am trying to read 65mV on ADC lines.but it still gives 0.
what is the minimum ADC input voltage range on ADC line of ESP32.
Posted: Tue Dec 05, 2017 1:34 pm
by vseven
ParthRathod wrote:Hello,
See the post I made right above yours. Its around 100 mv.
Posted: Tue Dec 19, 2017 8:18 pm
by urbanze
What happens if I set a voltage higher than the attenuation setting indicates? For example putting 3v with 0dB (1.1v) will burn the adc?
Posted: Tue Dec 19, 2017 8:20 pm
by vseven
No, as long as you don't go past the maximum of about 3.3 it will simply read max value above 1.1.
