ESP32 Pin Layout (for QFN 5*5), Pin25, Pin26
ajaymm58
Re: ESP32 Pin Layout (for QFN 5*5), Pin25, Pin26
Postby ajaymm58 » Tue Mar 28, 2017 1:04 am
iosixllc wrote:I'm sorry, the SAME?! Exactly?
Yes, EXACTLY SAME
iosixllc
Postby iosixllc » Tue Mar 28, 2017 1:06 am
Glad I caught this update ... gerbers went out last night and I was able to stop them and adjust this afternoon.
WiFive
Postby WiFive » Tue Mar 28, 2017 4:32 am
You are ordering boards for 5mm pkg? Is it available to sample/purchase?
iosixllc
Postby iosixllc » Tue Mar 28, 2017 5:59 am
Yes, plus it has built-in 2MB? flash in D2 configuration, so it's more secure and much smaller overall.
iosixllc
Postby iosixllc » Thu Mar 30, 2017 6:08 pm
Ok, so now there is another issue with the latest manual:
I can confirm from inspecting the part that it matches the first diagram. The question then is, is the second diagram wrong, and therefore are pins 1-14 on the long side?
Postby rudi ;-) » Thu Mar 30, 2017 6:46 pm
iosixllc wrote:Yes, plus it has built-in 2MB? flash in D2 configuration, so it's more secure and much smaller overall.
D2 would be 16 Mbit
Embedded Flash
0=No Embedded Flash
2=16 Mbit
iosixllc wrote: ..
I can confirm from inspecting ....
thank you iosixllc
i read between the lines
- ESP32 with embedded Flash is available
- you have this ESP32 SoC's get / in the hand from sales@espressif as samples and you can compare ( inspecting ) to the diagram practial with your own eyes on it ( on the SoC )
can u please say, which brandmark is on the chip?
ESP32-D2WDQ5
or better can you post a shoot of the SoC?
which number on it - produce date.
thank you
iosixllc
Postby iosixllc » Thu Mar 30, 2017 7:50 pm
Hi Rudi,
Yes, it's 16Mb = 2MB.
Yes, available in small quantities from sales. Yes I have 300 in front of me. Just preparing to re-spin board due to this issue. I don't think the pinout diagram showing the numbers is correct.
I can't get a good picture with my phone, unfortunately. Nor can I really read the inscription.
Postby rudi ;-) » Thu Mar 30, 2017 8:18 pm
iosixllc wrote:Hi Rudi,
hi iosixllc
thank you for your effort.
fine - so we see from you a nice esp32 embFlash board next time :) great!
let us knowing more about if you bring out
do you can read the produce numbers there are like this 2017xx or xx2017
what can you say, the marked pin1 point is this on the 1o pin side or on the 14 pin side,
do you think this can be the right :
think this must check one of the esp_guys cause just in time we have the embedded flash version not here at the desk ( yet )
i will ask sales@espressif why we have not yet :) ... 300 you say - hope for get it next time too.
we wait all for new things -
hope for your board design the best lucky diagram
edit: do you know, have you the silicon v0 or silicon v1 ?
and on your 300 pcs there are marked with
ESP32-D2WDQ5 - right?
Hans Dorn
Postby Hans Dorn » Thu Mar 30, 2017 9:00 pm
The pin 1 dot wouldn't line up with pin 1 if it was on the 14 pin side...
Cheers
iosixllc
Postby iosixllc » Thu Mar 30, 2017 9:18 pm
Right, but I have actual parts and they match the diagram that would indicate it's on the 14-pin side. That is the problem.
Users browsing this forum: No registered users and 49 guests
