I2S DMA
small coke
I2S DMA
Postby small coke » Fri Apr 03, 2020 2:12 am
I would like to inquire about using I2S to transmit voice. If using DMA, I want to generate an interrupt after the data is transmitted, but I do n’t see the DMA interrupt in the ESP32 technical manual, so I would like to ask the people who have used it to share it. Thank you very much for your experience!
Jakobsen
Re: I2S DMA
Postby Jakobsen » Fri Apr 03, 2020 7:31 am
Hi Small Coke
I've done that - It is quite easy just wait for i2s_evt.type == I2S_EVENT_TX_DONE using xQueueReceive(i2s_queue, &i2s_evt, portMAX_DELAY);
The queue handle you will get from you driver install setup call
i2s_driver_install(0, &i2s_config, 10, &i2s_queue);
Let me know if you need more liquor to spice up you coke :-)
/J
    double sweepPeriod     = 4;        // in sec
    uint32_t i = 0;
    i2s_event_t i2s_evt;
    sweepCnt = 0;
    freq = 50.0;
    angleSpeed  = 2*M_PI*freq/sampleRate;
    while (1) {
        if (i2s_evt.type == I2S_EVENT_TX_DONE)
        { timer_cnt++;
          switch (mode) {
            case 0 : gate = 1;              // Continues
                     break;
            case 1 :                  // Sweep
                     if (sweepCnt == 0 ) {
                       gate = 1;
                       freq = sweepStartFreq;
                     } else
                     { freq = freq * sweepSpeed;
                     if ( freq > sweepStopFreq )
                     { gate = 0;
                       //printf("sweepCnt : %d",sweepCnt);
                       sweepCnt = ( sweepCnt > sweepPeriod*lengthSig) ? 0 : sweepCnt + 1;
                     } else
                     { sweepCnt++;
Analog Digital IC designer / DevOps @ Merus Audio, Copenhagen, Denmark.
We do novel and best in class Audio amplifiers for consumer products.
Programmed assembler for C-64 back in 1980's, learned some electronics - hacking since then
small coke
Re: I2S DMA
Postby small coke » Fri Apr 03, 2020 12:51 pm
Thank you very much!I feel you are right, I already have ideas! :D
small coke
Re: I2S DMA
Postby small coke » Sat Apr 04, 2020 6:42 am
Sorry, I still have some problems. I had some ideas according to your statement before, but when I look back and continue to look at the code you provided, I do n’t know if I did n’t understand it or if your code is incomplete. In normal logic, I think your code is missing some braces. Forgive me for being a little white. There may be some offenses between words, sorry! :roll:
Jakobsen
Re: I2S DMA
Postby Jakobsen » Sat Apr 04, 2020 8:04 pm
Missing a lot ...
It is only a couple of lines from a signal generator component.
You can check out the full project from the repo :
https://github.com/jorgenkraghjakobsen/sig_gen.git
/j
Users browsing this forum: No registered users and 11 guests
