"flash read err, 1000" on custom ESP PICO D4 board
diyoio
Postby diyoio » Mon May 11, 2020 3:58 pm
I made a custom PCB following schematics of the ESP PICO D4 datasheet, made it printed and assembled by JLCPCB and I just received it but there is a problem.
When I connect my board UART to my computer I receive this continiously :
17:48:47.012 -> rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
17:48:47.012 -> flash read err, 1000
17:48:47.046 -> ets_⸮⸮⸮⸮⸮⸮
17:48:47.385 ->
17:48:47.385 -> rst:0x10 (⸮⸮⸮⸮⸮⸮-⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮?⸮⸮⸮P*⸮%==Q⸮
17:48:47.385 -> flash read err, 1000
17:48:47.385 -> ets_main.c 371
17:48:47.385 ->
17:48:47.757 -> rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASHGBGOT)
17:48:47.757 -> flash read err, 1000
17:48:47.757 -> ets_main.c 371
17:48:47.791 ->
When I press my BOOT button (putting GPIO0 LOW), the receive message change to :
17:57:13.830 -> rst:0x10 (RTCWDTORTCORESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
17:57:13.830 -> waiting for download
but then I receive a continous flow of 0x00 and I can't transfer my program...
Do you have any idea of the issue ?
Thanks.
chegewara
Re: "flash read err, 1000" on custom ESP PICO D4 board
Postby chegewara » Mon May 11, 2020 7:06 pm
First logs usually means there is nothing flashed yet. So you need to flash some app to it.
Second logs means device is awaiting you flash something to it.
ESP_Angus
Postby ESP_Angus » Tue May 12, 2020 3:36 am
As Chegewara says, the first message is normal for a chip trying to boot from empty flash (embedded flash in this case).
There shouldn't be any output after the output you've received. Can you confirm with a logic analyzer that it's actually outputting a correctly formed serial stream of 0x00 bytes? Is it possible there is some assembly issue which is causing noise on the UART RX or TX?
Users browsing this forum: No registered users and 13 guests
