Reflow PCB with WROVER on it?
Posted: Wed Aug 12, 2020 7:06 pm
by MStackoverflow
I'm getting a lot more into PCB design, but my work rate is very slow if I do everything by hand. I designed some custom PCB to fit an ESP32 WROVER-E on it.
In the manual , it says the absolute maximum rating is 150°C (storage temp).
If I put a PCB with a WROVER on it and I reflow the board at 165° top (low temperature solder paste), will it damage the board?
If yes, how do manufacturer make boards like HUZZAH or other dev boards?
If it work, how high I can set the temperature ? (Higher temp will allow for better solder paste)
Thank you.
Re: Reflow PCB with WROVER on it?
Posted: Thu Aug 13, 2020 7:33 am
by ESP_Sprite
Yes, during reflowing the Wrover can temporarily handle a higher temperature; the 'storage temperature' is more of a long-term thing. For details, refer to the 'reflow profile' in the datasheet.
Posted: Thu Aug 13, 2020 5:52 pm
by MStackoverflow
Thank you!
So, to reflow the PCB, do you recommend using paste that reflows at a lower temperature than the listed 235 ~ 250℃, or is a paste that reflows at the same temperature is fine?
Posted: Thu Aug 13, 2020 7:42 pm
by ESP_Sprite
Sorry, no clue, I'm not that familiar with soldering processes.
