ESP32 flash download
Any method to download bin file to flash without pressing the reset button using the command `make flash`? Thanks a lot
Re: ESP32 flash download
What devboard do you use? While the earliest versions had some issues with some OSses, all our devboards use a small two-transistor circuit that should automatically reset the ESP32 into boot mode when you run 'make flash'.
Users browsing this forum: Google [Bot] and 69 guests
