Having issues with Dual RS232-HS drivers
Posted: Thu May 13, 2021 8:42 pm
by orbitcoms
I was working with the Dual RS23-HS (on the ESP_PROG programmer) for a while just using serial com for flashing and monitoring in vscode (Interface 1 as com port)
Yesterday I wanted to look at using debugger with JTAG so I attached the ESP32-WROVER-KIT v 4.1 and the software could not find the debugger port (Interface 0).
I followed online advise to use Zadig to configure interface 0 as winusb but this did not work. Somehow I also managed to change driver on interface 1 and now cannot flash and monitor via serial port anymore. I have fiddled around trying to get it to work again and cannot. In windows it is shown as "Dual RS232-HS(Interface 1) COM17. Before is was simply "COM16". I have a setup at home also that still works using serial port and not that interface 1 driver is set up as HIDUSB.
Can someone please explain
1. How I can get my interface 1 set up properly as com port again
2. How to set up interface 0 for it to be found in vscode for debugging using openocd?
Re: Having issues with Dual RS232-HS drivers
Posted: Mon Feb 14, 2022 4:21 am
by pqkhanh561
I have same issue. Any help! Thanks!
