UART TX exact timing
kaspernyhus
Postby kaspernyhus » Fri Aug 19, 2022 2:31 pm
Is it possible to control the exact timing of a UART transmit?
I'm looking to do the following:
- Transmit one byte over UART eg. 0x35
- Wait 25ms
- Transmit the same byte again eg. 0x35
The result of
uint8_t data = 0x35;
uart_write_bytes(uart_num, &data, sizeof(data));
vTaskDelay(pdMS_TO_TICKS(25));
is the two bytes send right after each other. Changing the delay to 50 makes the wait time somewhat variable either 16ms or 24ms.
I suspect that the exact timing of the UART peripheral is outside our control? Or?
Thanks,
Kasper Nyhus
Re: UART TX exact timing
Postby ESP_Sprite » Sat Aug 20, 2022 2:43 am
Perhaps try calling uart_wait_tx_done() after sending the bytes.
kaspernyhus
Postby kaspernyhus » Sun Aug 21, 2022 1:03 pm
that absolutely improved the timing!
thanks once again ESP_Sprite
Users browsing this forum: No registered users and 54 guests
