Camera
Re: Camera
I want to be as closed as possible to Krzysztofs
great
https://github.com/krzychb/esp32-cam-demo#connect ;
Only want to port the idf-project to Arduino-IDE without freeRTOS.
The famous DMA-transfer is good to look at for further use.
I think i would do the reading out of the GRAM-Display with this.
With a function "snapshoot" (triggered by touch) that contents will be saved at an SD-card.
At the moment i struggle with one line in the code:
timer_conf.bit_num = 3;
in function:
static void enable_out_clock();
I've to learn more about PERIPH_LEDC_MODULE..
great
in function:
Re: Camera
"handmade" 3_BIT LEDC PWM depth ( LEDC channel duty depth ) or bug.
struggle result long version:
ledc_timer_config_t timer_conf;
timer_conf.bit_num
https://github.com/espressif/esp-idf/bl ... edc.h#L102
typedef struct {
ledc_mode_t speed_mode; /*!< LEDC speed speed_mode, high-speed mode or low-speed mode*/
ledc_timer_bit_t bit_num; /*!< LEDC channel duty depth*/
ledc_timer_t timer_num; /*!< The timer source of channel (0 - 3)*/
uint32_t freq_hz; /*!< LEDC timer frequency(Hz)*/
} ledc_timer_config_t;
ledc_timer_bit_t
https://github.com/espressif/esp-idf/bl ... ledc.h#L71
typedef enum {
LEDC_TIMER_10_BIT = 10, /*!< LEDC PWM depth 10Bit */
LEDC_TIMER_11_BIT = 11, /*!< LEDC PWM depth 11Bit */
LEDC_TIMER_12_BIT = 12, /*!< LEDC PWM depth 12Bit */
LEDC_TIMER_13_BIT = 13, /*!< LEDC PWM depth 13Bit */
LEDC_TIMER_14_BIT = 14, /*!< LEDC PWM depth 14Bit */
LEDC_TIMER_15_BIT = 15, /*!< LEDC PWM depth 15Bit */
} ledc_timer_bit_t;
btw:
OV7670 was init, but wait endless for VSYNC ( missing clock? -> Rigol next step )
Not sure where the mistake is, i will search further.
must to do ( i play with wRover Kit V2 )
to do with OV7670 ( without FIFO Version ) to get I2C Addr Probe ( 0x21 ) :
- Pullup SCL 10KOhm ( enough )
- CAM RST to 3.3
- PWRDWN bridge Resistor to GND
rudi
Re: Camera
This was the right hint.
I've changed it to :
timer_conf.bit_num = LEDC_TIMER_13_BIT;
and it compiled.
13-bit deep timer, i don't know, but seems to be right?
btw.:
The 8-bit Bus for the Display-Output Pins
-->d0 to d7
13,12,14,27,26,25,3,4
Don't use Pins 32 to 39.
These pins are the same for input-camera.
Only the direction has to change..
While the camera do the input the data will be written in GRAM(LCD).
Therefore befor the loop the
ucg.setPrintPos(0,0);
UCG_C10(0x0022) ; // LCD_WriteIndex(0x0022)
will perform that;
In the loop(Prgr.6) only the cam_out();
I use this camera(without reset and powerdown)
and it compiled.
btw.:
-->d0 to d7
will perform that;
Re: Camera
timer_conf.bit_num = LEDC_TIMER_13_BIT;erhardd wrote:This was the right hint.
and it compiled.
failed bit depth
look at: or bit_num. div_param=0rudi monitoring wrote: ..
D (475) camera: Enabling XCLK output
E (475) ledc: requested frequency and bit depth can not be achieved, try reducing freq_hz or bit_num. div_param=0
E (485) camera: ledc_timer_config failed, rc=ffffffff
I (485) ledc: LEDC_PWM CHANNEL 0|GPIO 21|Duty 0004|Time 0
LEDC_TIMER_0_BIT
rudi
edit:
(OV7670) btw:
rudi monitoring OV7670 wrote:
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x1e (SPI_FAST_FLASH_BOOT)
rst:0x10 (RTCWDT_RTC_RESET),boot:0x1e (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0x00
mode:DIO, clock div:2
load:0x3ffc0008,len:4
load:0x3ffc000c,len:1960
load:0x40078000,len:3724
load:0x40080000,len:260
entry 0x40080034
I (416) heap_alloc_caps: Initializing. RAM available for dynamic allocation:
I (416) heap_alloc_caps: At 3FFB1C80 len 0002E380 (184 KiB): DRAM
I (418) heap_alloc_caps: At 3FFE8000 len 00018000 (96 KiB): D/IRAM
I (427) heap_alloc_caps: At 4008F9BC len 00010644 (65 KiB): IRAM
I (436) cpu_start: Pro cpu up.
I (440) cpu_start: Single core mode
I (445) cpu_start: Pro cpu start user code
D (474) intr_alloc: Connected src 56 to int 2 (cpu 0)
I (477) cpu_start: Starting scheduler on PRO CPU.
D (482) camera: Enabling XCLK output
I (482) ledc: LEDC_PWM CHANNEL 0|GPIO 21|Duty 0004|Time 0
D (482) camera: Initializing SSCB
I (482) gpio: GPIO[26]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (492) gpio: GPIO[27]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (502) gpio: GPIO[26]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (512) gpio: GPIO[27]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
D (522) camera: Resetting camera
D (532) camera: Searching for camera address
D (532) camera: Detected camera at address=0x21
D (532) camera: Camera PID=0x76 VER=0x73 MIDL=0x7f MIDH=0xa2
D (542) camera: Doing SW reset of sensor
D (592) camera: Setting frame size
set_framesize: h=320 v=240
D (622) camera: Allocating frame buffer (320x240, 76800 bytes)
D (622) camera: Initializing I2S and DMA
I (622) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (622) gpio: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (632) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (642) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (652) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (652) gpio: GPIO[18]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (662) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (672) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (682) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (692) gpio: GPIO[23]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (702) gpio: GPIO[22]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
D (702) camera: Allocating DMA buffer #0, size=1280
D (712) camera: Allocating DMA buffer #1, size=1280
D (712) camera: Init done
D (722) camera: Waiting for VSYNC
Re: Camera
You can take GPIO32..39 as Input. That's right!
But I need an 8-bit Output for the ILI9325 (ucg-lib) and the pseudo-Input for CAM at the same pins..
p.s.:
Have you found the missing Vsync ?
Use you the VSPI for your ILI9341?
At Prgr.3 I display the contents of the SD-card(not included-->see http://esp32.com/viewtopic.php?f=19&t=702).
It is slow in VSPI (but right for slideshow)..
p.s.:
Re: Camera
i build with DevKitC/Nano32 again and the OV7670, prinzipal works now.erhardd wrote: You can take GPIO32..39 as Input. That's right!
p.s.:
must study the shematic from wRover kit V2,
there was a change on few pins,
one thing ,more, the QV7670 need pullups on SCL and RST must be pulled up ( 3.3 ) , the PWRDWN must pulled down ( GND ).
then OV7670 is talking SCCB, this result comes from "long night" testing,
for flashing with OV7670, break short RST from 3.3
http://esp32.com/viewtopic.php?f=12&t=344
btw the lcd D/C is same like Xclk.
rudi
( from SPI Flash )
"animated help service with audio"
on right side comes a live vid frame later.
- NoArduinoCode - its bareCode -
Re: Camera
https://github.com/espressif/esp-idf/tr ... 27_sd_card
(parts)
https://github.com/espressif/esp-idf/bl ... mmc_host.c
https://github.com/espressif/esp-idf/bl ... _private.h
https://github.com/espressif/esp-idf/bl ... nsaction.c
rudi
Re: Camera
Thanks for your hints!
At this point i decide to roll-back my Arduino-IDE.
Unexpectedly where everywhere Arduino15 folder are filed under Windows.
If there were no hardware i need like PC-Scope/Generator(Vellemann) and anymore I would prefer a Linux-Distri.
Re: Camera
HI @ all,
I did a port of the Arducam Mini 2MP OV2640 Arduino. Maybe that easy example some are looking for.
https://github.com/H-LK/ESP32_Arducam_Port
Anyway a direct access to the OV2640 would be awesome. Any progress yet?
Re: Camera
THIS IS MY RESULTS https://youtu.be/EdIFQ_LUx3Y
Users browsing this forum: Baidu [Spider], rolandlintz and 142 guests
