Weird WiFi behaviour
JPMJPM
Postby JPMJPM » Fri Oct 13, 2017 4:38 pm
The ESP32 send UDP data from a camera module to PC Windows and
it works only when I touch the ESP32 antenna.
Any clue ?. Thanks in advance.
santanapablo1975
Re: Weird WiFi behaviour
Postby santanapablo1975 » Tue Oct 17, 2017 4:57 pm
Hi
I it just a workaround, go to make menuconfig, and in the PHY section reduce the power to 0 dBm for example, and try again.
Regards
Juan
ESP_Angus
Postby ESP_Angus » Wed Oct 18, 2017 7:57 am
What ESP32 hardware (module, board, antenna, etc.) are you using?
JPMJPM
Postby JPMJPM » Thu Nov 23, 2017 4:04 pm
The camera module clock (20 MHz ) produced interference on the antenna.
The problem disappeared when the clock wire was shielded.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 36 guests
