About temprature_sens_read();
Re: About temprature_sens_read();
For a long time I've been waiting for some solution to reach a "real" temperature with this ... But now I need this for an industrial project. You have already said that in the future they have added a solution, but when will it come out? What can I do to use this temperature sensor as fast as possible?
Where does this come from? It's not in my SDK even correcting for spelling. I am locked into an SDK from around Feb so if it's been added that would explain why I can't find it.loboris wrote:Just add to your sourceCode: Select all
extern uint8_t temprature_sens_read();
John A
I am using uint8_t temprature_sens_read() but getting constant temperature 53.33 from ESP32 internal Sensor, Can anyone tell me what is actually going on and the solution so that I will get correct temperature information
- ijheflkjdf
To measure temperature without an external component Tom Stoeveken found a method --> https://github.com/Torxgewinde/ESP32-Temperature
It works but it is not very accurate.
Users browsing this forum: No registered users and 106 guests
