Dear ESP32 Members,
Does anyone know the schematic for this Dev board ?
https://www.aliexpress.com/item/Esp32-e ... 0.0.XFeuL2
And where can I find the original flash code ?
Any examples for it ?
A schematic for this dev board ?
Re: A schematic for this dev board ?
I got this on hello world example :
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT) | |
configsip: 0, SPIWP:0xee +-----------------------------+
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5556
load:0x40078000,len:0
load:0x40078000,len:13716
entry 0x40078fb4
I (28) boot: ESP-IDF v3.1-dev-162-geb659e4 2nd stage bootloader
I (29) boot: compile time 14:33:09
I (29) boot: Enabling RNG early entropy source...
I (35) boot: SPI Speed : 40MHz
I (39) boot: SPI Mode : DIO
I (43) boot: SPI Flash Size : 4MB
I (47) boot: Partition Table:
I (50) boot: ## Label Usage Type ST Offset Length
I (58) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (65) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (73) boot: 2 factory factory app 00 00 00010000 00100000
I (80) boot: End of partition table
I (84) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x04eb4 ( 20148) map
I (100) esp_image: segment 1: paddr=0x00014edc vaddr=0x3ffb0000 size=0x02140 ( 8512) load
I (105) esp_image: segment 2: paddr=0x00017024 vaddr=0x40080000 size=0x00400 ( 1024) load
I (111) esp_image: segment 3: paddr=0x0001742c vaddr=0x40080400 size=0x08444 ( 33860) load
I (134) esp_image: segment 4: paddr=0x0001f878 vaddr=0x400c0000 size=0x00000 ( 0) load
I (134) esp_image: segment 5: paddr=0x0001f880 vaddr=0x00000000 size=0x00790 ( 1936)
I (141) esp_image: segment 6: paddr=0x00020018 vaddr=0x400d0018 size=0x13340 ( 78656) map
I (182) boot: Loaded app from partition at offset 0x10000
I (182) boot: Disabling RNG early entropy source...
I (182) cpu_start: Pro cpu up.
I (186) cpu_start: Starting app cpu, entry point is 0x40080fe4
I (178) cpu_start: App cpu up.
I (197) heap_init: Initializing. RAM available for dynamic allocation:
I (203) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (209) heap_init: At 3FFB2948 len 0002D6B8 (181 KiB): DRAM
I (216) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (222) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (228) heap_init: At 40088844 len 000177BC (93 KiB): IRAM
I (235) cpu_start: Pro cpu start user code
I (253) cpu_start: Starting scheduler on PRO CPU.
Hello world!
This is ESP32 chip with 2 CPU cores, WiFi/BT/BLE, silicon revision 1, 4MB external flash
Restarting in 10 seconds...
Restarting in 9 seconds...
Restarting in 8 seconds...
Restarting in 7 seconds...
Restarting in 6 seconds...
Restarting in 5 seconds...
entry 0x40078fb4
Hello world!
This dev board uses the standard Wroom32 module from espressif.
The code that is currently loaded into the Chip is the standdard hello world application in the espressif ESP-IDF on githib.
You should be able to load and program all the standard examples to this board.
You can find the pinout of the Espressif module here:
The schematic of the boards varies with the vendor of the boards.
The best way is to search google images.
Hi !
Try this: https://www.hackster.io/johnnyfrx/esp32 ... ted-07ac5d
Not the schematics but definitely a good starting point.
Regards,
STB
Regards,
STB
Try to contact the seller, they usually can provide useful links.
And please share what you get
Users browsing this forum: No registered users and 133 guests
