External sRAM and flash connection with ESP32-PICO-D4
Posted: Mon Jun 11, 2018 1:22 pm
by habibh
Hello Group Members,
I want to connect external sRAM and flash with ESP32-PICO-D4 in my project. Can any one recommend how can I connect sRAM and flash with ESP32-PICO-D4 while I also need the functionality of Ethernet RMII in my project.
I shall be thankful for valuable suggestions.
Regards:
Habib
Re: External sRAM and flash connection with ESP32-PICO-D4
Posted: Thu Jun 14, 2018 1:06 pm
by habibh
Dear Group Members,
The data sheet of ESP332-PICO-D4 says that "Pins IO16, IO17, CMD, CLK, SD0 and SD1 are used for connecting the embedded flash, and are not recommended for other uses".
If I want to use an external flash with ESP32-PICO-D4 can I use the same pins as of integrated flash of ESP32-PICO-D4 with chip select different as shown in the following attachment ?
Regards:
Habib
Posted: Mon Apr 19, 2021 9:23 am
by luca_inter
hello habibh,
I would like use an external Flash memory to ESP32-Pico-D4, but I'm confused with the connections, please can you help me ?
thank you so much.
Best regards
