I have a WROVER board that comes with the PCB antenna connected. (from the schematic I assume R15 is connected and R14 is NOT connected).
If I want to use an external antenna connected to the ipex connector, do I need to remove R15 and move it to the R14 position? (I assume having both connected at the same time does not work).
WROVER PCB or IPex antenna
Re: WROVER PCB or IPex antenna
If I read the schematics in https://www.espressif.com/sites/default ... eet_en.pdf correctly, that's indeed what you need to do.
Users browsing this forum: No registered users and 77 guests
