GSM module circuit with ESP32 board
Sacp328
Postby Sacp328 » Mon Feb 11, 2019 5:49 pm
I am using quectal m95 gsm module with esp32 board to create a point to point cellular connection, Can i connect thier TX and RX pins directly or i need to do some volatge level conversions???
permal
Re: GSM module circuit with ESP32 board
Postby permal » Tue Feb 12, 2019 7:27 am
Check the datasheets for voltage levels. ESP32 uses 3.3V so if your devices uses the same you should be good to go.
Sacp328
Postby Sacp328 » Tue Feb 12, 2019 8:37 am
my gsm module uses something around 3.9 to 4 V, what should i do.
permal
Postby permal » Tue Feb 12, 2019 11:10 am
4V logic? Sounds like an odd value. Are you sure about that?
In any case, use a levelshifter, such as the TXB0102DCUR.
You could also use a simple voltage divider based on two resistors for each channel.
Users browsing this forum: No registered users and 24 guests
