Enabling DHCP server on WiFi station mode
shelving
Postby shelving » Mon Aug 08, 2022 9:09 pm
I've been trying to use a ESP32 device as a DHCP server.
I'm able to enable it when on Access Point mode but when switching to Station mode I haveno success.
Steps I'm taking:
  1. esp_netif_init();
  2. esp_event_loop_create_default();
  3.
  4. // Station mode
  5. esp_netif_t *my_sta = esp_netif_create_default_wifi_sta();
  6.
  7. // stop dhcp client and set a static IP address
  8. esp_netif_dhcpc_stop(my_sta);
  9. esp_netif_ip_info_t ip_info;
  10. // [...]
  11. esp_netif_set_ip_info(my_sta, &ip_info);
  12.
  13. // start dhcp server
  14. esp_netif_dhcps_start(my_sta);
  15.
  16. wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
  17. esp_wifi_init(&cfg);
  18. esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &event_handler, NULL);
  19. esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &event_handler, NULL);
  20.
  21. // connect to WiFi
  22. wifi_config_t wifi_config = {
  23.     .sta = {
  24.         .ssid = MY_SSID,
  25.         .password = MY_PASSWORD,
  26.     },
  27. };
  28. esp_wifi_set_mode(WIFI_MODE_STA);
  29. esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config);
  30. esp_wifi_start();
From this I'm able to connect to the wireless network and get an IP address (the static one), but the DHCP server doesn't start and stays at the INIT state.
ESP_YJM
Re: Enabling DHCP server on WiFi station mode
Postby ESP_YJM » Mon Aug 15, 2022 6:16 am
STA netif not support DHCP server. You should create a AP netif and run DHCP server on it.
Users browsing this forum: Abisha and 276 guests
