Dual core
urbanze
Re: Dual core
Postby urbanze » Mon Jun 12, 2017 2:37 pm
kolban wrote:@urbanze,
A question if I may. Do you really need "dual core" or do you need "multi task"?
What is the nature of your solution where you think you need to harness the power of dual core processors as opposed to a potential logical design where your design calls for multi-tasking?
You can run multiple parallel loops with multi-tasking that don't involve multi-core. I'd like to hear your use case that calls for true dual core support?
oh god, i reply wrong.. this reply is to RITESH.
thanks!.. i make a lot of test when esp32 come to my hand's :twisted:
JohnKed
Re: Dual core
Postby JohnKed » Mon Jun 26, 2017 3:03 pm
I'm a newbie with the ESP32 and I have a few question about multicore programming with arduino!
By reading this post I understand that I can use the two cores only by using the FreeRTOS. Is this correct?
Can somehow program the chip to something like void
setup1()
void loop1()
void setup2()
void loop2()
without using the RTOS?
kolban
Re: Dual core
Postby kolban » Mon Jun 26, 2017 5:08 pm
Mr pcbreflux did a great video on using multi-tasking in Arduino land ... see:
https://www.youtube.com/watch?v=i8ffEbyU-7w&t=6s
and give it a thumbs up.
JohnKed
Re: Dual core
Postby JohnKed » Tue Jun 27, 2017 10:09 am
Thanks kolban! It was very helpful
ahue32
Re: Dual core
Postby ahue32 » Fri Jan 12, 2018 12:15 pm
Is it possible to call a function to run on core 1 when it is called inside the loop on core 0? To make it clearer, I have Bluetooth communication on core 0 and read the touch input from a touch display on core 1. When there is a Bluetooth notification the characteristic value is read in loop on core 0 and the display should be updated. I want to update it on core 1, but I have the feeling that
xTaskCreatePinnedToCore(...)
is not good inside loop. Are there other methods to define on which core a function runs? Or to call this function again once its created?
Re: Dual core
Postby ESP_Sprite » Sat Jan 13, 2018 3:10 am
Theoretically, you could create a task and destroy it every time you want to update the display, but indeed, this is not very efficient. It's better to have a permanent task on core 1 that normally waits for a semaphore or task notification and gets to work as soon as it receives this.
Ritesh
Contact:
Re: Dual core
Postby Ritesh » Tue Jan 16, 2018 5:33 pm
ESP_Sprite wrote:Theoretically, you could create a task and destroy it every time you want to update the display, but indeed, this is not very efficient. It's better to have a permanent task on core 1 that normally waits for a semaphore or task notification and gets to work as soon as it receives this.
Let's consider that I need to create one application in which it requires almost 9 to 10 different tasks with different priority and stack size then which method is better like create & delete each task if not required permanent or create all tasks initially and wait for task notify event for that particular task?
Because I think it's waste of memory if we create Initially without any requirement.
Let me correct if I am wrong.
Regards,
Ritesh Prajapati
