http request over ethernet
burkulesomesh43
Postby burkulesomesh43 » Thu Aug 16, 2018 7:24 am
Hi all,
I want to send data using http server.
the http_request example is given in esp idf over wifi.
can we use that example over ethernet??
Somesh Burkule
kolban
Re: http request over ethernet
Postby kolban » Thu Aug 16, 2018 4:10 pm
Howdy my friend,
Can you provide the link to the sample you are looking at?
Can I confirm that you want to send an HTTP request to an HTTP Server as opposed to an HTTP server running on the ESP32 sending a request somewhere else?
At the highest level, the networking subsystem at the low levels takes care of physical communication (WiFi or Ethernet) while the higher level protocols (TCP/IP) "just work" over those physical mediums. As such, any applications written to the higher level APIs such as "sockets" should "just work".
fly135
Postby fly135 » Thu Aug 16, 2018 7:08 pm
burkulesomesh43 wrote:Hi all,
My guess would be that wifi vs internet is transparent to the http server code.
So the question would be... do you know how to start up the ethernet? Do you have a board with ethernet?
I don't have an ESP32 with ethernet and haven't seen one. But I'm guessing that if you can get the ethernet example in the IDF to start and give you an IP address, then any network code like the HTTP server will just automagically work.
John A
Ritesh
Contact:
Postby Ritesh » Fri Aug 17, 2018 1:30 am
Yes. You can use that example over Ethernet as well. You just need to enable Ethernet and init required configuration to enable it.
Then, You can get external connectivity like WiFi.
Regards,
Ritesh Prajapati
burkulesomesh43
Postby burkulesomesh43 » Sat Aug 18, 2018 1:35 pm
Ok thank you.
Somesh Burkule
Ritesh
Contact:
Postby Ritesh » Sat Aug 18, 2018 5:39 pm
Ok thank you.
Let me know if need any help regarding that.
Regards,
Ritesh Prajapati
burkulesomesh43
Postby burkulesomesh43 » Mon Aug 20, 2018 5:46 am
Ok thank you.
Nop. thank you.
My code is working now properly. I am sending data to http server over ethernet.
Somesh Burkule
Ritesh
Contact:
Postby Ritesh » Mon Aug 20, 2018 4:32 pm
Ritesh wrote:
burkulesomesh43 wrote: Ok thank you.
Nop. thank you.
Great. Good to share sample code for others who want to test same like you have tested if not confidential.
Regards,
Ritesh Prajapati
Users browsing this forum: No registered users and 61 guests
