Hi All.
So, scanning through the API reference, it appears there are two different methods to attach an ISR the Pulse Counter:
* pcnt_isr_service_install() / pcnt_isr_handler_add()
* pcnt_isr_register()
However, I haven't yet found an explanation of what the difference between these two is. Anyone have an explanation or a pointer to an explanation?
Thanks.
Attach ISR to Pulse Counter
Re: Attach ISR to Pulse Counter
pcnt_isr_register is only if you want to write your own low level isr
Thanks. Is that distinction documented somewhere?
Not sure, but it is common to most of the peripheral drivers. The interrupt service manages its own isr so it will call pcnt_isr_register internally.
Users browsing this forum: Bing [Bot], djixon, douglasbaird, eriksl and 114 guests
