ESP32 Installation problem
antyvirus
Postby antyvirus » Sat Apr 13, 2019 9:18 am
I try to install Esp32 with this guide https://docs.espressif.com/projects/esp ... n-packages. I have problem in step 8. This is what i have on screen
[Codebox]$ make flash ESPPORT=COM6
Toolchain path: /opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a5
Compiler version: 5.2.0
CC build/bootloader/bootloader_support/src/bootloader_random.o
CC build/bootloader/bootloader_support/src/flash_encrypt.o
CC build/bootloader/bootloader_support/src/bootloader_sha.o
CC build/bootloader/bootloader_support/src/esp_image_format.o
CC build/bootloader/bootloader_support/src/flash_partitions.o
CC build/bootloader/bootloader_support/src/bootloader_clock.o
CC build/bootloader/bootloader_support/src/secure_boot.o
CC build/bootloader/bootloader_support/src/bootloader_common.o
CC build/bootloader/bootloader_support/src/bootloader_utility.o
CC build/bootloader/bootloader_support/src/bootloader_init.o
CC build/bootloader/bootloader_support/src/secure_boot_signatures.o
CC build/bootloader/bootloader_support/src/flash_qio_mode.o
CC build/bootloader/bootloader_support/src/bootloader_flash.o
AR build/bootloader/bootloader_support/libbootloader_support.a
CC build/bootloader/log/log.o
AR build/bootloader/log/liblog.a
CC build/bootloader/spi_flash/spi_flash_rom_patch.o
AR build/bootloader/spi_flash/libspi_flash.a
CC build/bootloader/micro-ecc/micro-ecc/uECC.o
AR build/bootloader/micro-ecc/libmicro-ecc.a
CC build/bootloader/soc/esp32/rtc_clk.o
CC build/bootloader/soc/esp32/rtc_time.o
CC build/bootloader/soc/esp32/rtc_sleep.o
CC build/bootloader/soc/esp32/gpio_periph.o
CC build/bootloader/soc/esp32/rtc_clk_init.o
CC build/bootloader/soc/esp32/spi_periph.o
CC build/bootloader/soc/esp32/rtc_init.o
CC build/bootloader/soc/esp32/sdio_slave_periph.o
CC build/bootloader/soc/esp32/rtc_wdt.o
CC build/bootloader/soc/esp32/sdmmc_periph.o
CC build/bootloader/soc/esp32/cpu_util.o
CC build/bootloader/soc/esp32/rtc_periph.o
CC build/bootloader/soc/esp32/rtc_pm.o
CC build/bootloader/soc/esp32/soc_memory_layout.o
CC build/bootloader/soc/src//memory_layout_utils.o
AR build/bootloader/soc/libsoc.a
CC build/bootloader/main/bootloader_start.o
AR build/bootloader/main/libmain.a
CC build/bootloader/efuse/esp32/esp_efuse_table.o
CC build/bootloader/efuse/src/esp_efuse_fields.o
CC build/bootloader/efuse/src/esp_efuse_utility.o
CC build/bootloader/efuse/src/esp_efuse_api.o
AR build/bootloader/efuse/libefuse.a
LD build/bootloader/bootloader.elf
esptool.py v2.7-dev
Python requirements from C:/msys32/home/Komputer_2/esp/esp-idf/requirements.txt are satisfied.
Building partitions from /home/Komputer_2/esp/esp-idf/components/partition_table/partitions_singleapp.csv...
CC build/app_trace/heap_trace_tohost.o
CC build/app_trace/app_trace.o
CC build/app_trace/host_file_io.o
CC build/app_trace/app_trace_util.o
CC build/app_trace/gcov/gcov_rtio.o
AR build/app_trace/libapp_trace.a
Project is not inside a git repository, will not use 'git describe' to determine PROJECT_VER.
App "blink" version: 1
CC build/app_update/esp_app_desc.o
CC build/app_update/esp_ota_ops.o
AR build/app_update/libapp_update.a
CXX build/asio/asio/asio/src/asio.o
AR build/asio/libasio.a
AR build/aws_iot/libaws_iot.a
CC build/bootloader_support/src/bootloader_random.o
CC build/bootloader_support/src/flash_encrypt.o
CC build/bootloader_support/src/bootloader_sha.o
CC build/bootloader_support/src/esp_image_format.o
CC build/bootloader_support/src/flash_partitions.o
CC build/bootloader_support/src/bootloader_clock.o
CC build/bootloader_support/src/secure_boot.o
CC build/bootloader_support/src/bootloader_common.o
CC build/bootloader_support/src/bootloader_utility.o
CC build/bootloader_support/src/secure_boot_signatures.o
CC build/bootloader_support/src/flash_qio_mode.o
CC build/bootloader_support/src/bootloader_flash.o
AR build/bootloader_support/libbootloader_support.a
CC build/bt/bt.o
AR build/bt/libbt.a
CC build/coap/libcoap/src/address.o
CC build/coap/libcoap/src/async.o
CC build/coap/libcoap/src/block.o
CC build/coap/libcoap/src/coap_event.o
CC build/coap/libcoap/src/coap_hashkey.o
CC build/coap/libcoap/src/coap_session.o
CC build/coap/libcoap/src/coap_time.o
CC build/coap/libcoap/src/coap_debug.o
CC build/coap/libcoap/src/encode.o
CC build/coap/libcoap/src/mem.o
CC build/coap/libcoap/src/net.o
CC build/coap/libcoap/src/option.o
CC build/coap/libcoap/src/pdu.o
CC build/coap/libcoap/src/resource.o
CC build/coap/libcoap/src/str.o
CC build/coap/libcoap/src/subscribe.o
CC build/coap/libcoap/src/uri.o
CC build/coap/libcoap/src/coap_notls.o
CC build/coap/port/coap_io.o
AR build/coap/libcoap.a
CC build/console/linenoise/linenoise.o
CC build/console/argtable3/argtable3.o
CC build/console/commands.o
CC build/console/split_argv.o
AR build/console/libconsole.a
CXX build/cxx/cxx_exception_stubs.o
CXX build/cxx/cxx_guards.o
AR build/cxx/libcxx.a
CC build/driver/rtc_module.o
CC build/driver/i2c.o
CC build/driver/sdmmc_host.o
CC build/driver/spi_slave.o
CC build/driver/can.o
CC build/driver/sdmmc_transaction.o
CC build/driver/mcpwm.o
CC build/driver/rmt.o
CC build/driver/sdspi_crc.o
CC build/driver/pcnt.o
CC build/driver/timer.o
CC build/driver/gpio.o
CC build/driver/sdspi_host.o
CC build/driver/ledc.o
CC build/driver/periph_ctrl.o
CC build/driver/i2s.o
CC build/driver/sdio_slave.o
CC build/driver/sdspi_transaction.o
CC build/driver/uart.o
CC build/driver/sigmadelta.o
CC build/driver/spi_master.o
CC build/driver/spi_common.o
AR build/driver/libdriver.a
CC build/efuse/esp32/esp_efuse_table.o
CC build/efuse/src/esp_efuse_fields.o
CC build/efuse/src/esp_efuse_utility.o
CC build/efuse/src/esp_efuse_api.o
AR build/efuse/libefuse.a
CC build/esp-tls/esp_tls.o
AR build/esp-tls/libesp-tls.a
CC build/esp32/int_wdt.o
CC build/esp32/brownout.o
CC build/esp32/system_api.o
CC build/esp32/esp_himem.o
CC build/esp32/dport_access.o
CC build/esp32/hw_random.o
CC build/esp32/pm_esp32.o
CC build/esp32/reset_reason.o
CC build/esp32/intr_alloc.o
CC build/esp32/cache_err_int.o
CC build/esp32/spiram.o
CC build/esp32/clk.o
CC build/esp32/spiram_psram.o
CC build/esp32/esp_timer_esp32.o
CC build/esp32/pm_trace.o
CC build/esp32/crosscore_int.o
CC build/esp32/gdbstub.o
CC build/esp32/cache_sram_mmu.o
CC build/esp32/cpu_start.o
CC build/esp32/sleep_modes.o
CC build/esp32/task_wdt.o
CC build/esp32/esp_adapter.o
CC build/esp32/panic.o
AS build/esp32/dport_panic_highint_hdl.o
AR build/esp32/libesp32.a
CC build/esp_adc_cal/esp_adc_cal.o
AR build/esp_adc_cal/libesp_adc_cal.a
CC build/esp_common/src/esp_timer.o
CC build/esp_common/src/stack_check.o
CC build/esp_common/src/esp_err_to_name.o
CC build/esp_common/src/pm_locks.o
CC build/esp_common/src/ipc.o
CC build/esp_common/src/ets_timer_legacy.o
CC build/esp_common/src/freertos_hooks.o
CC build/esp_common/src/dbg_stubs.o
AR build/esp_common/libesp_common.a
CC build/esp_event/esp_event_private.o
CC build/esp_event/esp_event.o
CC build/esp_event/event_loop.o
CC build/esp_event/event_default_handlers.o
CC build/esp_event/default_event_loop.o
AR build/esp_event/libesp_event.a
CC build/esp_http_client/esp_http_client.o
CC build/esp_http_client/lib/http_utils.o
CC build/esp_http_client/lib/http_auth.o
CC build/esp_http_client/lib/http_header.o
AR build/esp_http_client/libesp_http_client.a
CC build/esp_http_server/src/httpd_sess.o
CC build/esp_http_server/src/httpd_parse.o
CC build/esp_http_server/src/httpd_uri.o
CC build/esp_http_server/src/httpd_txrx.o
CC build/esp_http_server/src/httpd_main.o
CC build/esp_http_server/src/util/ctrl_sock.o
AR build/esp_http_server/libesp_http_server.a
CC build/esp_https_ota/src/esp_https_ota.o
AR build/esp_https_ota/libesp_https_ota.a
CC build/esp_https_server/src/https_server.o
AR build/esp_https_server/libesp_https_server.a
CC build/esp_ringbuf/ringbuf.o
AR build/esp_ringbuf/libesp_ringbuf.a
CC build/esp_rom/esp_rom.o
AR build/esp_rom/libesp_rom.a
CC build/esp_wifi/src/wifi_init.o
CC build/esp_wifi/src/coexist.o
CC build/esp_wifi/src/fast_crypto_ops.o
CC build/esp_wifi/src/phy_init.o
CC build/esp_wifi/src/restore.o
CC build/esp_wifi/src/lib_printf.o
AR build/esp_wifi/libesp_wifi.a
CC build/espcoredump/src/core_dump_uart.o
CC build/espcoredump/src/core_dump_common.o
CC build/espcoredump/src/core_dump_flash.o
CC build/espcoredump/src/core_dump_port.o
AR build/espcoredump/libespcoredump.a
CC build/ethernet/emac_main.o
CC build/ethernet/emac_dev.o
CC build/ethernet/eth_phy/phy_tlk110.o
CC build/ethernet/eth_phy/phy_ip101.o
CC build/ethernet/eth_phy/phy_lan8720.o
CC build/ethernet/eth_phy/phy_common.o
AR build/ethernet/libethernet.a
CC build/expat/expat/expat/lib/xmltok_impl.o
CC build/expat/expat/expat/lib/xmlrole.o
CC build/expat/expat/expat/lib/xmlparse.o
CC build/expat/expat/expat/lib/xmltok.o
CC build/expat/expat/expat/lib/xmltok_ns.o
CC build/expat/expat/expat/lib/loadlibrary.o
AR build/expat/libexpat.a
CC build/fatfs/src/diskio.o
CC build/fatfs/src/vfs_fat.o
CC build/fatfs/src/vfs_fat_spiflash.o
CC build/fatfs/src/diskio_sdmmc.o
CC build/fatfs/src/vfs_fat_sdmmc.o
CC build/fatfs/src/diskio_rawflash.o
CC build/fatfs/src/ffunicode.o
CC build/fatfs/src/ff.o
CC build/fatfs/src/diskio_wl.o
CC build/fatfs/src/ffsystem.o
AR build/fatfs/libfatfs.a
CC build/freemodbus/modbus/mb.o
CC build/freemodbus/port/portevent.o
CC build/freemodbus/port/portserial.o
CC build/freemodbus/port/porttimer.o
CC build/freemodbus/port/portother.o
CC build/freemodbus/modbus/ascii/mbascii.o
CC build/freemodbus/modbus/functions/mbutils.o
CC build/freemodbus/modbus/functions/mbfunccoils.o
CC build/freemodbus/modbus/functions/mbfuncdiag.o
CC build/freemodbus/modbus/functions/mbfuncother.o
CC build/freemodbus/modbus/functions/mbfuncdisc.o
CC build/freemodbus/modbus/functions/mbfuncinput.o
CC build/freemodbus/modbus/functions/mbfuncholding.o
CC build/freemodbus/modbus/rtu/mbrtu.o
CC build/freemodbus/modbus/rtu/mbcrc.o
CC build/freemodbus/modbus_controller/mbcontroller.o
AR build/freemodbus/libfreemodbus.a
CC build/freertos/xtensa_overlay_os_hook.o
CC build/freertos/FreeRTOS-openocd.o
CC build/freertos/timers.o
CC build/freertos/tasks.o
CC build/freertos/event_groups.o
CC build/freertos/port.o
CC build/freertos/xtensa_init.o
CC build/freertos/list.o
CC build/freertos/croutine.o
CC build/freertos/queue.o
CC build/freertos/xtensa_intr.o
AS build/freertos/portasm.o
AS build/freertos/xtensa_vector_defaults.o
AS build/freertos/xtensa_vectors.o
AS build/freertos/xtensa_context.o
AS build/freertos/xtensa_intr_asm.o
AR build/freertos/libfreertos.a
CC build/heap/heap_caps_init.o
CC build/heap/heap_caps.o
CC build/heap/multi_heap.o
AR build/heap/libheap.a
AR build/idf_test/libidf_test.a
CC build/jsmn/src//jsmn.o
AR build/jsmn/libjsmn.a
CC build/json/cJSON/cJSON.o
CC build/json/cJSON/cJSON_Utils.o
AR build/json/libjson.a
CC build/libsodium/port/randombytes_esp32.o
CC build/libsodium/libsodium/src/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.o
CC build/libsodium/libsodium/src/libsodium/crypto_aead/xchacha20poly1305/sodium/aead_xchacha20poly1305.o
CC build/libsodium/libsodium/src/libsodium/crypto_auth/crypto_auth.o
CC build/libsodium/libsodium/src/libsodium/crypto_auth/hmacsha256/auth_hmacsha256.o
CC build/libsodium/libsodium/src/libsodium/crypto_auth/hmacsha512/auth_hmacsha512.o
CC build/libsodium/libsodium/src/libsodium/crypto_auth/hmacsha512256/auth_hmacsha512256.o
CC build/libsodium/libsodium/src/libsodium/crypto_box/crypto_box_easy.o
CC build/libsodium/libsodium/src/libsodium/crypto_box/crypto_box.o
CC build/libsodium/libsodium/src/libsodium/crypto_box/crypto_box_seal.o
CC build/libsodium/libsodium/src/libsodium/crypto_box/curve25519xsalsa20poly1305/box_curve25519xsalsa20poly1305.o
CC build/libsodium/libsodium/src/libsodium/crypto_core/curve25519/ref10/curve25519_ref10.o
CC build/libsodium/libsodium/src/libsodium/crypto_core/hchacha20/core_hchacha20.o
CC build/libsodium/libsodium/src/libsodium/crypto_core/hsalsa20/ref2/core_hsalsa20_ref2.o
CC build/libsodium/libsodium/src/libsodium/crypto_core/hsalsa20/core_hsalsa20.o
CC build/libsodium/libsodium/src/libsodium/crypto_core/salsa/ref/core_salsa_ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/crypto_generichash.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/generichash_blake2.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-sse41.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-ssse3.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/generichash_blake2b.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-avx2.o
CC build/libsodium/libsodium/src/libsodium/crypto_hash/crypto_hash.o
CC build/libsodium/libsodium/src/libsodium/crypto_hash/sha256/hash_sha256.o
CC build/libsodium/libsodium/src/libsodium/crypto_hash/sha512/hash_sha512.o
CC build/libsodium/libsodium/src/libsodium/crypto_kdf/blake2b/kdf_blake2b.o
CC build/libsodium/libsodium/src/libsodium/crypto_kdf/crypto_kdf.o
CC build/libsodium/libsodium/src/libsodium/crypto_kx/crypto_kx.o
CC build/libsodium/libsodium/src/libsodium/crypto_onetimeauth/crypto_onetimeauth.o
CC build/libsodium/libsodium/src/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.o
CC build/libsodium/libsodium/src/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/argon2-encoding.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/argon2-fill-block-ssse3.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/pwhash_argon2i.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/argon2-fill-block-ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/argon2.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/blake2b-long.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/argon2/argon2-core.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/crypto_pwhash.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/pbkdf2-sha256.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/crypto_scrypt-common.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/pwhash_scryptsalsa208sha256.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/scrypt_platform.o
CC build/libsodium/libsodium/src/libsodium/crypto_pwhash/scryptsalsa208sha256/nosse/pwhash_scryptsalsa208sha256_nosse.o
CC build/libsodium/libsodium/src/libsodium/crypto_scalarmult/crypto_scalarmult.o
CC build/libsodium/libsodium/src/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.o
CC build/libsodium/libsodium/src/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.o
CC build/libsodium/libsodium/src/libsodium/crypto_secretbox/crypto_secretbox.o
CC build/libsodium/libsodium/src/libsodium/crypto_secretbox/crypto_secretbox_easy.o
CC build/libsodium/libsodium/src/libsodium/crypto_secretbox/xsalsa20poly1305/secretbox_xsalsa20poly1305.o
CC build/libsodium/libsodium/src/libsodium/crypto_shorthash/crypto_shorthash.o
CC build/libsodium/libsodium/src/libsodium/crypto_shorthash/siphash24/shorthash_siphash24.o
CC build/libsodium/libsodium/src/libsodium/crypto_shorthash/siphash24/shorthash_siphashx24.o
CC build/libsodium/libsodium/src/libsodium/crypto_shorthash/siphash24/ref/shorthash_siphashx24_ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_shorthash/siphash24/ref/shorthash_siphash24_ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_sign/crypto_sign.o
CC build/libsodium/libsodium/src/libsodium/crypto_sign/ed25519/sign_ed25519.o
CC build/libsodium/libsodium/src/libsodium/crypto_sign/ed25519/ref10/keypair.o
CC build/libsodium/libsodium/src/libsodium/crypto_sign/ed25519/ref10/open.o
CC build/libsodium/libsodium/src/libsodium/crypto_sign/ed25519/ref10/sign.o
CC build/libsodium/libsodium/src/libsodium/crypto_sign/ed25519/ref10/obsolete.o
CC build/libsodium/libsodium/src/libsodium/crypto_stream/chacha20/stream_chacha20.o
CC build/libsodium/libsodium/src/libsodium/crypto_stream/chacha20/ref/chacha20_ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_stream/crypto_stream.o
CC build/libsodium/libsodium/src/libsodium/crypto_stream/salsa20/stream_salsa20.o
CC build/libsodium/libsodium/src/libsodium/crypto_stream/salsa20/ref/salsa20_ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_stream/xsalsa20/stream_xsalsa20.o
CC build/libsodium/libsodium/src/libsodium/crypto_verify/sodium/verify.o
CC build/libsodium/libsodium/src/libsodium/randombytes/randombytes.o
CC build/libsodium/libsodium/src/libsodium/sodium/utils.o
CC build/libsodium/libsodium/src/libsodium/sodium/runtime.o
CC build/libsodium/libsodium/src/libsodium/sodium/version.o
CC build/libsodium/libsodium/src/libsodium/sodium/core.o
CC build/libsodium/port/crypto_hash_mbedtls/crypto_hash_sha512_mbedtls.o
CC build/libsodium/port/crypto_hash_mbedtls/crypto_hash_sha256_mbedtls.o
AR build/libsodium/liblibsodium.a
CC build/log/log.o
AR build/log/liblog.a
CC build/lwip/apps/dhcpserver/dhcpserver.o
CC build/lwip/apps/ping/esp_ping.o
CC build/lwip/apps/ping/ping.o
CC build/lwip/lwip/src/api/sockets.o
CC build/lwip/lwip/src/api/api_msg.o
CC build/lwip/lwip/src/api/err.o
CC build/lwip/lwip/src/api/netbuf.o
CC build/lwip/lwip/src/api/tcpip.o
CC build/lwip/lwip/src/api/netifapi.o
CC build/lwip/lwip/src/api/api_lib.o
CC build/lwip/lwip/src/api/netdb.o
CC build/lwip/lwip/src/apps/sntp/sntp.o
CC build/lwip/lwip/src/core/tcp_out.o
CC build/lwip/lwip/src/core/udp.o
CC build/lwip/lwip/src/core/def.o
CC build/lwip/lwip/src/core/stats.o
CC build/lwip/lwip/src/core/netif.o
CC build/lwip/lwip/src/core/pbuf.o
CC build/lwip/lwip/src/core/tcp_in.o
CC build/lwip/lwip/src/core/raw.o
CC build/lwip/lwip/src/core/ip.o
CC build/lwip/lwip/src/core/dns.o
CC build/lwip/lwip/src/core/timeouts.o
CC build/lwip/lwip/src/core/tcp.o
CC build/lwip/lwip/src/core/sys.o
CC build/lwip/lwip/src/core/memp.o
CC build/lwip/lwip/src/core/init.o
CC build/lwip/lwip/src/core/inet_chksum.o
CC build/lwip/lwip/src/core/mem.o
CC build/lwip/lwip/src/core/ipv4/icmp.o
CC build/lwip/lwip/src/core/ipv4/autoip.o
CC build/lwip/lwip/src/core/ipv4/ip4.o
CC build/lwip/lwip/src/core/ipv4/igmp.o
CC build/lwip/lwip/src/core/ipv4/ip4_addr.o
CC build/lwip/lwip/src/core/ipv4/etharp.o
CC build/lwip/lwip/src/core/ipv4/dhcp.o
CC build/lwip/lwip/src/core/ipv4/ip4_frag.o
CC build/lwip/lwip/src/core/ipv6/icmp6.o
CC build/lwip/lwip/src/core/ipv6/ethip6.o
CC build/lwip/lwip/src/core/ipv6/mld6.o
CC build/lwip/lwip/src/core/ipv6/nd6.o
CC build/lwip/lwip/src/core/ipv6/ip6.o
CC build/lwip/lwip/src/core/ipv6/ip6_addr.o
CC build/lwip/lwip/src/core/ipv6/inet6.o
CC build/lwip/lwip/src/core/ipv6/dhcp6.o
CC build/lwip/lwip/src/core/ipv6/ip6_frag.o
CC build/lwip/lwip/src/netif/ethernetif.o
CC build/lwip/lwip/src/netif/lowpan6.o
CC build/lwip/lwip/src/netif/ethernet.o
CC build/lwip/lwip/src/netif/slipif.o
CC build/lwip/port/esp32/vfs_lwip.o
CC build/lwip/port/esp32/freertos/sys_arch.o
CC build/lwip/port/esp32/netif/ethernetif.o
CC build/lwip/port/esp32/netif/dhcp_state.o
CC build/lwip/port/esp32/netif/wlanif.o
CC build/lwip/port/esp32/debug/lwip_debug.o
AR build/lwip/liblwip.a
CC build/main/blink.o
AR build/main/libmain.a
CC build/mbedtls/mbedtls/library/poly1305.o
CC build/mbedtls/mbedtls/library/platform_util.o
CC build/mbedtls/mbedtls/library/havege.o
CC build/mbedtls/mbedtls/library/ssl_cookie.o
CC build/mbedtls/mbedtls/library/md5.o
CC build/mbedtls/mbedtls/library/certs.o
CC build/mbedtls/mbedtls/library/ssl_ciphersuites.o
CC build/mbedtls/mbedtls/library/camellia.o
CC build/mbedtls/mbedtls/library/x509_crl.o
CC build/mbedtls/mbedtls/library/threading.o
CC build/mbedtls/mbedtls/library/aesni.o
CC build/mbedtls/mbedtls/library/bignum.o
CC build/mbedtls/mbedtls/library/arc4.o
CC build/mbedtls/mbedtls/library/cipher_wrap.o
CC build/mbedtls/mbedtls/library/rsa_internal.o
CC build/mbedtls/mbedtls/library/aes.o
CC build/mbedtls/mbedtls/library/xtea.o
CC build/mbedtls/mbedtls/library/base64.o
CC build/mbedtls/mbedtls/library/sha512.o
CC build/mbedtls/mbedtls/library/pkcs11.o
CC build/mbedtls/mbedtls/library/ecdsa.o
CC build/mbedtls/mbedtls/library/asn1write.o
CC build/mbedtls/mbedtls/library/oid.o
CC build/mbedtls/mbedtls/library/ecjpake.o
CC build/mbedtls/mbedtls/library/ssl_tls.o
CC build/mbedtls/mbedtls/library/debug.o
CC build/mbedtls/mbedtls/library/aria.o
CC build/mbedtls/mbedtls/library/ecdh.o
CC build/mbedtls/mbedtls/library/x509_crt.o
CC build/mbedtls/mbedtls/library/ssl_srv.o
CC build/mbedtls/mbedtls/library/sha1.o
CC build/mbedtls/mbedtls/library/chacha20.o
CC build/mbedtls/mbedtls/library/md2.o
CC build/mbedtls/mbedtls/library/x509_create.o
CC build/mbedtls/mbedtls/library/cmac.o
CC build/mbedtls/mbedtls/library/gcm.o
CC build/mbedtls/mbedtls/library/version.o
CC build/mbedtls/mbedtls/library/pem.o
CC build/mbedtls/mbedtls/library/padlock.o
CC build/mbedtls/mbedtls/library/asn1parse.o
CC build/mbedtls/mbedtls/library/timing.o
CC build/mbedtls/mbedtls/library/ssl_cli.o
CC build/mbedtls/mbedtls/library/pkwrite.o
CC build/mbedtls/mbedtls/library/ssl_cache.o
CC build/mbedtls/mbedtls/library/sha256.o
CC build/mbedtls/mbedtls/library/md_wrap.o
CC build/mbedtls/mbedtls/library/entropy.o
CC build/mbedtls/mbedtls/library/hkdf.o
CC build/mbedtls/mbedtls/library/rsa.o
CC build/mbedtls/mbedtls/library/ripemd160.o
CC build/mbedtls/mbedtls/library/nist_kw.o
CC build/mbedtls/mbedtls/library/pkcs5.o
CC build/mbedtls/mbedtls/library/version_features.o
CC build/mbedtls/mbedtls/library/cipher.o
CC build/mbedtls/mbedtls/library/entropy_poll.o
CC build/mbedtls/mbedtls/library/dhm.o
CC build/mbedtls/mbedtls/library/error.o
CC build/mbedtls/mbedtls/library/ssl_ticket.o
CC build/mbedtls/mbedtls/library/x509.o
CC build/mbedtls/mbedtls/library/blowfish.o
CC build/mbedtls/mbedtls/library/chachapoly.o
CC build/mbedtls/mbedtls/library/ecp.o
CC build/mbedtls/mbedtls/library/md4.o
CC build/mbedtls/mbedtls/library/x509_csr.o
CC build/mbedtls/mbedtls/library/pkparse.o
CC build/mbedtls/mbedtls/library/md.o
CC build/mbedtls/mbedtls/library/ccm.o
CC build/mbedtls/mbedtls/library/pkcs12.o
CC build/mbedtls/mbedtls/library/ecp_curves.o
CC build/mbedtls/mbedtls/library/pk_wrap.o
CC build/mbedtls/mbedtls/library/x509write_crt.o
CC build/mbedtls/mbedtls/library/ctr_drbg.o
CC build/mbedtls/mbedtls/library/platform.o
CC build/mbedtls/mbedtls/library/pk.o
CC build/mbedtls/mbedtls/library/x509write_csr.o
CC build/mbedtls/mbedtls/library/des.o
CC build/mbedtls/mbedtls/library/hmac_drbg.o
CC build/mbedtls/mbedtls/library/memory_buffer_alloc.o
CC build/mbedtls/port/esp_sha512.o
CC build/mbedtls/port/esp_mem.o
CC build/mbedtls/port/esp_hardware.o
CC build/mbedtls/port/net_sockets.o
CC build/mbedtls/port/esp_bignum.o
CC build/mbedtls/port/esp_sha256.o
CC build/mbedtls/port/esp_sha1.o
CC build/mbedtls/port/mbedtls_debug.o
CC build/mbedtls/port/esp32/aes.o
CC build/mbedtls/port/esp32/sha.o
AR build/mbedtls/libmbedtls.a
CC build/mdns/mdns.o
CC build/mdns/mdns_networking.o
CC build/mdns/mdns_console.o
AR build/mdns/libmdns.a
CC build/mqtt/esp-mqtt/mqtt_client.o
CC build/mqtt/esp-mqtt/lib/platform_esp32_idf.o
CC build/mqtt/esp-mqtt/lib/mqtt_msg.o
CC build/mqtt/esp-mqtt/lib/mqtt_outbox.o
AR build/mqtt/libmqtt.a
CC build/newlib/select.o
CC build/newlib/pthread.o
CC build/newlib/random.o
CC build/newlib/locks.o
CC build/newlib/utime.o
CC build/newlib/poll.o
CC build/newlib/syscall_table.o
CC build/newlib/syscalls.o
CC build/newlib/termios.o
CC build/newlib/reent_init.o
CC build/newlib/time.o
AR build/newlib/libnewlib.a
CC build/nghttp/nghttp2/lib/nghttp2_map.o
CC build/nghttp/nghttp2/lib/nghttp2_queue.o
CC build/nghttp/nghttp2/lib/nghttp2_pq.o
CC build/nghttp/nghttp2/lib/nghttp2_submit.o
CC build/nghttp/nghttp2/lib/nghttp2_debug.o
CC build/nghttp/nghttp2/lib/nghttp2_hd_huffman_data.o
CC build/nghttp/nghttp2/lib/nghttp2_frame.o
CC build/nghttp/nghttp2/lib/nghttp2_helper.o
CC build/nghttp/nghttp2/lib/nghttp2_npn.o
CC build/nghttp/nghttp2/lib/nghttp2_option.o
CC build/nghttp/nghttp2/lib/nghttp2_buf.o
CC build/nghttp/nghttp2/lib/nghttp2_priority_spec.o
CC build/nghttp/nghttp2/lib/nghttp2_hd.o
CC build/nghttp/nghttp2/lib/nghttp2_stream.o
CC build/nghttp/nghttp2/lib/nghttp2_session.o
CC build/nghttp/nghttp2/lib/nghttp2_callbacks.o
CC build/nghttp/nghttp2/lib/nghttp2_rcbuf.o
CC build/nghttp/nghttp2/lib/nghttp2_hd_huffman.o
CC build/nghttp/nghttp2/lib/nghttp2_mem.o
CC build/nghttp/nghttp2/lib/nghttp2_version.o
CC build/nghttp/nghttp2/lib/nghttp2_outbound_item.o
CC build/nghttp/nghttp2/lib/nghttp2_http.o
CC build/nghttp/port/http_parser.o
AR build/nghttp/libnghttp.a
CXX build/nvs_flash/src/nvs_api.o
CXX build/nvs_flash/src/nvs_storage.o
CXX build/nvs_flash/src/nvs_pagemanager.o
CXX build/nvs_flash/src/nvs_encr.o
CXX build/nvs_flash/src/nvs_item_hash_list.o
CXX build/nvs_flash/src/nvs_page.o
CXX build/nvs_flash/src/nvs_ops.o
CXX build/nvs_flash/src/nvs_types.o
AR build/nvs_flash/libnvs_flash.a
CC build/openssl/library/ssl_stack.o
CC build/openssl/library/ssl_lib.o
CC build/openssl/library/ssl_x509.o
CC build/openssl/library/ssl_pkey.o
CC build/openssl/library/ssl_methods.o
CC build/openssl/library/ssl_cert.o
CC build/openssl/platform/ssl_port.o
CC build/openssl/platform/ssl_pm.o
AR build/openssl/libopenssl.a
CC build/protobuf-c/protobuf-c/protobuf-c/protobuf-c.o
AR build/protobuf-c/libprotobuf-c.a
CC build/protocomm/src/common/protocomm.o
CC build/protocomm/src/security/security1.o
CC build/protocomm/src/security/security0.o
CC build/protocomm/proto-c/sec0.pb-c.o
CC build/protocomm/proto-c/constants.pb-c.o
CC build/protocomm/proto-c/session.pb-c.o
CC build/protocomm/proto-c/sec1.pb-c.o
CC build/protocomm/src/transports/protocomm_httpd.o
CC build/protocomm/src/transports/protocomm_console.o
AR build/protocomm/libprotocomm.a
CC build/pthread/pthread.o
CC build/pthread/pthread_cond_var.o
CC build/pthread/pthread_local_storage.o
AR build/pthread/libpthread.a
CC build/sdmmc/sdmmc_sd.o
CC build/sdmmc/sdmmc_cmd.o
CC build/sdmmc/sdmmc_mmc.o
CC build/sdmmc/sdmmc_common.o
CC build/sdmmc/sdmmc_io.o
CC build/sdmmc/sdmmc_init.o
AR build/sdmmc/libsdmmc.a
CC build/smartconfig_ack/smartconfig_ack.o
AR build/smartconfig_ack/libsmartconfig_ack.a
CC build/soc/esp32/rtc_clk.o
CC build/soc/esp32/rtc_time.o
CC build/soc/esp32/rtc_sleep.o
CC build/soc/esp32/gpio_periph.o
CC build/soc/esp32/rtc_clk_init.o
CC build/soc/esp32/spi_periph.o
CC build/soc/esp32/rtc_init.o
CC build/soc/esp32/sdio_slave_periph.o
CC build/soc/esp32/rtc_wdt.o
CC build/soc/esp32/sdmmc_periph.o
CC build/soc/esp32/cpu_util.o
CC build/soc/esp32/rtc_periph.o
CC build/soc/esp32/rtc_pm.o
CC build/soc/esp32/soc_memory_layout.o
CC build/soc/src//memory_layout_utils.o
AR build/soc/libsoc.a
CC build/spi_flash/flash_ops.o
CC build/spi_flash/cache_utils.o
CC build/spi_flash/spi_flash_rom_patch.o
CC build/spi_flash/partition.o
CC build/spi_flash/flash_mmap.o
AR build/spi_flash/libspi_flash.a
CC build/spiffs/esp_spiffs.o
CC build/spiffs/spiffs_api.o
CC build/spiffs/spiffs/src/spiffs_hydrogen.o
CC build/spiffs/spiffs/src/spiffs_check.o
CC build/spiffs/spiffs/src/spiffs_nucleus.o
CC build/spiffs/spiffs/src/spiffs_gc.o
CC build/spiffs/spiffs/src/spiffs_cache.o
AR build/spiffs/libspiffs.a
CC build/tcp_transport/transport_strcasestr.o
CC build/tcp_transport/transport_tcp.o
CC build/tcp_transport/transport.o
CC build/tcp_transport/transport_ssl.o
CC build/tcp_transport/transport_utils.o
CC build/tcp_transport/transport_ws.o
AR build/tcp_transport/libtcp_transport.a
CC build/tcpip_adapter/tcpip_adapter_lwip.o
AR build/tcpip_adapter/libtcpip_adapter.a
CC build/ulp/ulp_macro.o
CC build/ulp/ulp.o
AR build/ulp/libulp.a
CC build/unity/unity/src/unity.o
CC build/unity/unity_port_esp32.o
CC build/unity/unity_runner.o
AR build/unity/libunity.a
CC build/vfs/vfs.o
CC build/vfs/vfs_semihost.o
CC build/vfs/vfs_uart.o
AR build/vfs/libvfs.a
CXX build/wear_levelling/WL_Ext_Perf.o
CXX build/wear_levelling/Partition.o
CXX build/wear_levelling/SPI_Flash.o
CXX build/wear_levelling/WL_Ext_Safe.o
CXX build/wear_levelling/crc32.o
CXX build/wear_levelling/WL_Flash.o
CXX build/wear_levelling/wear_levelling.o
AR build/wear_levelling/libwear_levelling.a
CC build/wifi_provisioning/src/wifi_config.o
CC build/wifi_provisioning/proto-c/wifi_config.pb-c.o
CC build/wifi_provisioning/proto-c/wifi_constants.pb-c.o
AR build/wifi_provisioning/libwifi_provisioning.a
CC build/wpa_supplicant/src/crypto/ms_funcs.o
CC build/wpa_supplicant/src/crypto/crypto_internal-cipher.o
CC build/wpa_supplicant/src/crypto/crypto_internal-modexp.o
CC build/wpa_supplicant/src/crypto/bignum.o
CC build/wpa_supplicant/src/crypto/sha1-pbkdf2.o
CC build/wpa_supplicant/src/crypto/aes-cbc.o
CC build/wpa_supplicant/src/crypto/md5.o
CC build/wpa_supplicant/src/crypto/rc4.o
CC build/wpa_supplicant/src/crypto/sha256.o
CC build/wpa_supplicant/src/crypto/dh_groups.o
CC build/wpa_supplicant/src/crypto/md4-internal.o
CC build/wpa_supplicant/src/crypto/sha1-internal.o
CC build/wpa_supplicant/src/crypto/aes-wrap.o
CC build/wpa_supplicant/src/crypto/crypto_mbedtls.o
CC build/wpa_supplicant/src/crypto/crypto_internal.o
CC build/wpa_supplicant/src/crypto/dh_group5.o
CC build/wpa_supplicant/src/crypto/des-internal.o
CC build/wpa_supplicant/src/crypto/crypto_internal-rsa.o
CC build/wpa_supplicant/src/crypto/aes-unwrap.o
CC build/wpa_supplicant/src/crypto/aes-internal-dec.o
CC build/wpa_supplicant/src/crypto/sha1.o
CC build/wpa_supplicant/src/crypto/aes-internal.o
CC build/wpa_supplicant/src/crypto/md5-internal.o
CC build/wpa_supplicant/src/crypto/sha256-internal.o
CC build/wpa_supplicant/src/crypto/aes-internal-enc.o
CC build/wpa_supplicant/port/os_xtensa.o
CC build/wpa_supplicant/src/fast_crypto/fast_crypto_internal-cipher.o
CC build/wpa_supplicant/src/fast_crypto/fast_crypto_internal-modexp.o
CC build/wpa_supplicant/src/fast_crypto/fast_aes-unwrap.o
CC build/wpa_supplicant/src/fast_crypto/fast_sha256.o
CC build/wpa_supplicant/src/fast_crypto/fast_crypto_internal.o
CC build/wpa_supplicant/src/fast_crypto/fast_aes-cbc.o
CC build/wpa_supplicant/src/fast_crypto/fast_sha256-internal.o
CC build/wpa_supplicant/src/fast_crypto/fast_aes-wrap.o
CC build/wpa_supplicant/src/wpa2/eap_peer/eap_peap_common.o
CC build/wpa_supplicant/src/wpa2/eap_peer/chap.o
CC build/wpa_supplicant/src/wpa2/eap_peer/eap_mschapv2.o
CC build/wpa_supplicant/src/wpa2/eap_peer/eap_peap.o
CC build/wpa_supplicant/src/wpa2/eap_peer/eap_ttls.o
CC build/wpa_supplicant/src/wpa2/eap_peer/eap_tls_common.o
CC build/wpa_supplicant/src/wpa2/eap_peer/eap_tls.o
CC build/wpa_supplicant/src/wpa2/eap_peer/mschapv2.o
CC build/wpa_supplicant/src/wpa2/eap_peer/eap_common.o
CC build/wpa_supplicant/src/wpa2/eap_peer/eap.o
CC build/wpa_supplicant/src/wpa2/tls/tls_internal.o
CC build/wpa_supplicant/src/wpa2/tls/tlsv1_common.o
CC build/wpa_supplicant/src/wpa2/tls/tlsv1_server_write.o
CC build/wpa_supplicant/src/wpa2/tls/bignum.o
CC build/wpa_supplicant/src/wpa2/tls/tlsv1_record.o
CC build/wpa_supplicant/src/wpa2/tls/pkcs5.o
CC build/wpa_supplicant/src/wpa2/tls/pkcs1.o
CC build/wpa_supplicant/src/wpa2/tls/tlsv1_client_write.o
CC build/wpa_supplicant/src/wpa2/tls/tlsv1_server_read.o
CC build/wpa_supplicant/src/wpa2/tls/asn1.o
CC build/wpa_supplicant/src/wpa2/tls/pkcs8.o
CC build/wpa_supplicant/src/wpa2/tls/rsa.o
CC build/wpa_supplicant/src/wpa2/tls/tlsv1_client.o
CC build/wpa_supplicant/src/wpa2/tls/tlsv1_client_read.o
CC build/wpa_supplicant/src/wpa2/tls/tlsv1_cred.o
CC build/wpa_supplicant/src/wpa2/tls/x509v3.o
CC build/wpa_supplicant/src/wpa2/tls/tlsv1_server.o
CC build/wpa_supplicant/src/wpa2/utils/ext_password.o
CC build/wpa_supplicant/src/wpa2/utils/base64.o
CC build/wpa_supplicant/src/wps/wps_enrollee.o
CC build/wpa_supplicant/src/wps/uuid.o
CC build/wpa_supplicant/src/wps/wps_attr_build.o
CC build/wpa_supplicant/src/wps/wps_registrar.o
CC build/wpa_supplicant/src/wps/wps_common.o
CC build/wpa_supplicant/src/wps/wps.o
CC build/wpa_supplicant/src/wps/wps_dev_attr.o
CC build/wpa_supplicant/src/wps/wps_attr_parse.o
CC build/wpa_supplicant/src/wps/wps_validate.o
CC build/wpa_supplicant/src/wps/wps_attr_process.o
CC build/wpa_supplicant/src/wps/eap_common.o
AR build/wpa_supplicant/libwpa_supplicant.a
CC build/xtensa/trax.o
CC build/xtensa/eri.o
AR build/xtensa/libxtensa.a
Generating libapp_trace.a.sections_info
Generating libapp_update.a.sections_info
Generating libasio.a.sections_info
Generating libaws_iot.a.sections_info
Generating libbootloader_support.a.sections_info
Generating libbt.a.sections_info
Generating libcoap.a.sections_info
Generating libconsole.a.sections_info
Generating libcxx.a.sections_info
Generating libdriver.a.sections_info
Generating libefuse.a.sections_info
Generating libesp-tls.a.sections_info
Generating libesp32.a.sections_info
Generating libesp_adc_cal.a.sections_info
Generating libesp_common.a.sections_info
Generating libesp_event.a.sections_info
Generating libesp_http_client.a.sections_info
Generating libesp_http_server.a.sections_info
Generating libesp_https_ota.a.sections_info
Generating libesp_https_server.a.sections_info
Generating libesp_ringbuf.a.sections_info
Generating libesp_rom.a.sections_info
Generating libesp_wifi.a.sections_info
Generating libespcoredump.a.sections_info
Generating libethernet.a.sections_info
Generating libexpat.a.sections_info
Generating libfatfs.a.sections_info
Generating libfreemodbus.a.sections_info
Generating libfreertos.a.sections_info
Generating libheap.a.sections_info
Generating libidf_test.a.sections_info
Generating libjsmn.a.sections_info
Generating libjson.a.sections_info
Generating liblibsodium.a.sections_info
Generating liblog.a.sections_info
Generating liblwip.a.sections_info
Generating libmain.a.sections_info
Generating libmbedtls.a.sections_info
Generating libmdns.a.sections_info
Generating libmqtt.a.sections_info
Generating libnewlib.a.sections_info
Generating libnghttp.a.sections_info
Generating libnvs_flash.a.sections_info
Generating libopenssl.a.sections_info
Generating libprotobuf-c.a.sections_info
Generating libprotocomm.a.sections_info
Generating libpthread.a.sections_info
Generating libsdmmc.a.sections_info
Generating libsmartconfig_ack.a.sections_info
Generating libsoc.a.sections_info
Generating libspi_flash.a.sections_info
Generating libspiffs.a.sections_info
Generating libtcp_transport.a.sections_info
Generating libtcpip_adapter.a.sections_info
Generating libulp.a.sections_info
Generating libunity.a.sections_info
Generating libvfs.a.sections_info
Generating libwear_levelling.a.sections_info
Generating libwifi_provisioning.a.sections_info
Generating libwpa_supplicant.a.sections_info
Generating libxtensa.a.sections_info
Generating esp32.project.ld
LD build/blink.elf
esptool.py v2.7-dev
Flashing binaries to serial port COM6 (app at offset 0x10000)...
esptool.py v2.7-dev
Serial port COM6
Connecting........_____....._____....._____....._____....._____....._____....._____
make: *** [/home/Komputer_2/esp/esp-idf/components/esptool_py/Makefile.projbuild:67: flash] Błąd 2
[/Codebox]
lph65724
Re: ESP32 Installation problem
Postby lph65724 » Tue Apr 23, 2019 8:49 am
You may wanna check your COM port. It's either your ESP32 board is actually connected to another COM port or you have another terminal using COM6
Users browsing this forum: Google [Bot] and 21 guests
