I'm trying to initialize and use the ESP32's SPI Master interface, using a logic analyzer to monitor the MOSI and CLK signals. The MOSI signal seems to make sense but the clock signal doesn't appear anywhere...
I'm attaching a snapshot of a single transaction, together with the initialization and transaction code. Is anything wrong with the initialization code?
#define SPI_MASTER_CLOCK 500000
#define SPI_MASTER_MISO 12
#define SPI_MASTER_MOSI 13
#define SPI_MASTER_CLK 14
#define SPI_MASTER_SL_CS 15
#define SPI_MASTER_ACC_CS 24
//!SPI Master device handle
spi_device_handle_t _spi_master;
//!Initialize SPI Master interface
void spiMasterInit()
esp_err_t ret;
ESP_LOGI(TAG, "spiMasterInit: Initializing SPI Master peripheral");
spi_bus_config_t buscfg =
.miso_io_num = SPI_MASTER_MISO,
.mosi_io_num = SPI_MASTER_MOSI,
.sclk_io_num = SPI_MASTER_CLK,
.quadwp_io_num=-1,
.quadhd_io_num=-1,
.max_transfer_sz = SPI_MAX_DMA_LEN,
spi_device_interface_config_t simple_link_dev_cfg =
.clock_speed_hz = SPI_MASTER_CLOCK, //Clock out at 10 MHz
.mode = 0, //SPI mode 0
.spics_io_num = SPI_MASTER_SL_CS, //CS pin
.queue_size = 1, //We want to be able to queue 1 transaction at a time
.command_bits = 0, //skip command phase of transmission
.address_bits = 0, //skip address phase of transmission
.dummy_bits = 0, //clock speed is set low, therefore dummy bits need not be set
.cs_ena_pretrans = 1,
.cs_ena_posttrans = 1,
.flags = 0, //
.pre_cb = NULL, //no pre transaction callback function
.post_cb = NULL, //no post transaction callback function
ret = spi_bus_initialize(HSPI_HOST, &buscfg, 2); //initialize the SPI bus
ESP_ERROR_CHECK(ret);
ret = spi_bus_add_device(HSPI_HOST, &simple_link_dev_cfg, &_spi_master); //attach device
//!Transmit over SPI Master interface
int32_t spiMasterTransmit(char* data, uint16_t data_len)
esp_err_t trans_result = ESP_OK;
spi_transaction_t transaction =
.tx_buffer = NULL, //transmit buffer
.rx_buffer = NULL, //no read, transmit only
.tx_data[0] = 0x01,
.tx_data[1] = 0x02,
.tx_data[2] = 0x03,
.tx_data[3] = 0x04,
.length = 8*4, //set data length (bits)
.flags = SPI_TRANS_USE_TXDATA,
.cmd = 0, //command phase skipped
.addr = 0, //address phase skipped
.user = (void*)1, //user defined variable
ESP_LOGI(TAG, "spiMasterTransmit: Initializing SPI transaction");
trans_result = spi_device_polling_transmit(_spi_master, &transaction);
if(ESP_OK == trans_result)
ESP_LOGI(TAG, "spiMasterTransmit: Transmitted data successfully");
else
ESP_LOGE(TAG, "spiMasterTransmit: Could not manage data transmission");
return FAILED_OPERATION;
return data_len;
