IR Nec example
peter_
IR Nec example
Postby peter_ » Tue Jan 31, 2017 10:41 am
I have problems running the IR-example with a real transceiver/receiver.
I'm getting sometimes this error:
rmt: RMT RX BUFFER FULL
I'm getting this in normal use after some time. The easiest way for me to reproduce this is to run the code in self test mode with a real transceiver/receiver. It seems that
if(item) {
becomes false before this happens. So if I get it right the buffer should be empty.
I will append my Log. I have add a debug output at line 312 "No return of item".
By the way, the margin is to small for real receivers. (20µS is only one carrier wave cycle) I have set it to 120µS.
Can anybody help me with this issue?
Regards
Peter
espLog.txt.zip
Log
(1016 Bytes) Downloaded 134 times
tharunjoy
Re: IR Nec example
Postby tharunjoy » Wed Jul 10, 2019 7:20 am
I am also getting the same issue.
tharunjoy
Re: IR Nec example
Postby tharunjoy » Tue Aug 13, 2019 3:41 pm
Please check out this thread
https://esp32.com/viewtopic.php?f=13&t= ... 818#p47818
If you are still on these issues, the above thread will definitely help you
Thank you.
Users browsing this forum: No registered users and 17 guests
