Simple question regarding the avrc passthrough command
agualuso
Postby agualuso » Mon Jun 10, 2019 3:21 pm
I'm using the a2dp_sink example and i want to do simple button tasks like pausing, increasing/decreasing the volume and so on.
Im using esp_avrc_ct_send_passthrough_cmd() inside of a task. The problem is that the passthrough command doesn't do anything, when i make monitor and click the button the task executes but it doesn't do anything. I get this: RCCT: AVRC passthrough rsp: key_code 0x46, key_state 0
This is the task code:
static void pause_task(void* arg) {
	uint32_t io_num;
		for(;;) {
		     if(xQueueReceive(gpio_evt_queue, &io_num, portMAX_DELAY)){
			if(gpio_get_level(GPIO_INPUT_IO_1)==1){
				printf("Pause\n");
				esp_avrc_ct_send_passthrough_cmd(0,ESP_AVRC_PT_CMD_PAUSE ,ESP_AVRC_PT_CMD_STATE_PRESSED);
Am i using the command in the wrong way or is the task incorrectly made ?
Users browsing this forum: No registered users and 21 guests
