ESP32 freezes for a couple of seconds when the Wifi network is lost.
rjrajbir
Postby rjrajbir » Wed Jun 19, 2019 5:38 am
Hi, When I turn off the Wi-Fi router, the LED starts to interrupt the blinking after it is restored. As soon as I turn on the router again, the LED stops flashing, it happens several times, and then everything works fine. Probably the loop starts to slow down while working on connecting to Wifi. How can I avoid this?
I have the following sketch:
#include <WiFi.h>
#include <WebSocketsClient.h>
unsigned int timer;
  pinMode(2, OUTPUT);
  /* Connect Wifi Network */
 WiFi.begin("SSID", "PASS");
  /* Connect WebSocket Server */
  webSocket.begin("ip", 2342, "/"); // Connect WebSocket Server
  webSocket.onEvent(webSocketEvent); // Set WebSocket Event Function
  webSocket.setReconnectInterval(5000); // Set WebSocket Reconnect Interval
  webSocket.loop();
  if((millis() - timer) >= 250) {
   if(digitalRead(2) == LOW) {
     digitalWrite(2, HIGH);
     digitalWrite(2, LOW);
   timer = millis();
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) {
   String payload_str = String((char*) payload);
   const char* payload_set_str = payload_str.c_str();
	switch(type) {
		case WStype_CONNECTED:
		case WStype_TEXT:
Users browsing this forum: No registered users and 153 guests
