Problem installing IDF on linux
aaronpadilla
Postby aaronpadilla » Sun Jul 21, 2019 1:46 pm
I am not able to install EPS-IDF tools, here the dump:
aaron@aaron-crachoir:~/esp$ cd esp-idf/
aaron@aaron-crachoir:~/esp/esp-idf$ ./install.sh
Installing ESP-IDF tools
Installing tools: xtensa-esp32-elf, esp32ulp-elf, openocd-esp32
Skipping xtensa-esp32-elf@esp32-2019r1-8.2.0 (already installed)
File "/home/aaron/esp/esp-idf/tools/idf_tools.py", line 1250, in <module>
main(sys.argv[1:])
File "/home/aaron/esp/esp-idf/tools/idf_tools.py", line 1246, in main
action_func(args)
File "/home/aaron/esp/esp-idf/tools/idf_tools.py", line 1038, in action_install
assert tool_version is not None
AssertionError
could you advice?
Thanks in advance.
ESP_igrr
Re: Problem installing IDF on linux
Postby ESP_igrr » Sun Jul 21, 2019 6:08 pm
Are you running a 32-bit (x86) version of Linux?
It seems we don't have 32-bit builds of some of the tools which are marked "required" for the installation. We will correct that.
Ritesh
Contact:
Postby Ritesh » Mon Jul 22, 2019 7:31 pm
ESP32 IDF can't be installed on 32 bit Linux System? We are also using 64 bit Linux System and didn't try to us it into 32 but system.
Regards,
Ritesh Prajapati
mishafarms
Postby mishafarms » Wed Jul 24, 2019 12:40 pm
I am having this issue with a Raspberry pi 4 (still 32 bit I assume).
Any suggestions?
Michael
Ritesh
Contact:
Postby Ritesh » Thu Jul 25, 2019 5:13 am
Any suggestions?
Michael
ESP_igrr,
Would you please help them regarding this issue if you have any idea regarding that issue?
Regards,
Ritesh Prajapati
mishafarms
Postby mishafarms » Sun Jul 28, 2019 4:28 am
I tried this all from scratch again. I had some minor issues I need to look at again with a fresh install. But everything seems to
be working now. I have a Raspberry pi 4 (4G) with an ESP32 development environment including eclipse.
Very Cool
Michael
Ritesh
Contact:
Postby Ritesh » Tue Jul 30, 2019 5:18 am
Very Cool
Michael
Great. Thanks for update regarding that.
Let me know if need any help into future for that.
Regards,
Ritesh Prajapati
Users browsing this forum: No registered users and 247 guests
