ESP-IDF problems with mingw/mingw32/make
Patsjemoe
Postby Patsjemoe » Mon Aug 05, 2019 7:23 am
I followed the instructions to install ESP-IDF, but have problems when coming to the instruction "make menuconfig".
This is not working, and tried about everything you can find on the web...without any succes.
Somewhere, I read that espressif only works with mingw32.
Unfortunately, this world is very confusing, as there is mingw, mingw32, and what with running mingw64, because of a 64 bit system.
Could someone clarify exactly what you have to install to get "make" to work....this means which version of software, which paths to define in which place (windows or in profile.d) ?
I hope to find a solution, as it took me already 3 days without progress.
Thanks in advance
best regards
Ludo
WiFive
Re: ESP-IDF problems with mingw/mingw32/make
Postby WiFive » Mon Aug 05, 2019 7:41 am
Which instructions? These https://docs.espressif.com/projects/esp ... setup.html ?
Mingw32.exe runs fine on a 64 bit system.
Patsjemoe
Postby Patsjemoe » Mon Aug 05, 2019 8:00 am
thanks, but I followed already this document, but no solution.
have followed all instructions, and make does not work.
now I have an additional problem :
IDF_PATH cannot contain colons. If overriding IDF_PATH on Windows, use MSYS Unix-style /c/dir instead of C:/dir. I tried to change this, but windows does not allow /c/....(see attachement).
regards
Ludo
Patsjemoe
Postby Patsjemoe » Mon Aug 05, 2019 8:28 am
hi,
thanks for your feedback.
Unfortunately, I already followed these instructions without succes.
Trying to fix it, I added IDF_PATH to windows, but got following error :
I changed this, but got an error (see attachement) .
Then I deleted completely the windows path to IDF, and kept only the paths to MSYS32/usr/bin to the make file.
Strange enough, I do not have any IDF path in windows anymore, but still get the same error IDF PAth cannot contain colons....
regards
Ludo
WiFive
Postby WiFive » Mon Aug 05, 2019 6:54 pm
https://docs.espressif.com/projects/esp ... ml#windows
You want to add it to the path in the msys2 environment not the windows environment. In general if you are using msys2 just pretend windows doesn't even exist.
Patsjemoe
Postby Patsjemoe » Tue Aug 06, 2019 9:31 am
I have put it in c/msys32/et/profile.d/export_adf_path
But as it does not work, I also tried to put it in windows.
In mingw32, nothing happens, I get following error :
$ make menuconfig
Makefile:2: /project.mk: No such file or directory
make: *** No rule to make target '/project.mk'. Stop.
Still stuck...
Regards
Ludo
WiFive
Postby WiFive » Tue Aug 06, 2019 8:37 pm
Close MSYS2 window and open it again. Check if IDF_PATH is set, by typing:
printenv IDF_PATH
The path previusly entered in the script file should be printed out.
If you do not like to have IDF_PATH set up permanently in user profile, you should enter it manually on opening of an MSYS2 window:
export IDF_PATH="C:/msys32/home/user-name/esp/esp-idf"
Patsjemoe
Postby Patsjemoe » Sat Aug 10, 2019 5:28 am
somehow, the system does not take the IDF_PATH file in profile.d directory.
when I now manually export it, the path is returned (there was confusion of the export IDF_PATH, which in a documents also was written as EXPORT_IDF_PATH as name.....so had to do export export_idf_path)
I now have following error :
$ make menuconfig
0 [main] make (6616) C:\msys32\usr\bin\make.exe: *** fatal error - cygheap base mismatch detected - 0x642D5408/0x612B6408.
Have re-installed cygwin, but error remains.
I think to re-install everything, but the problem is that there are several different documents, some of them refer to old versions. If there was 1 "latest" version, it would be good.
What I also do not understand is that some documents refer to mingw32, some documents refer to cmd.exe...............can I only use cmd.exe , and what should/not I install then ?
1 document with clear instructions would be very welcome.
regards
Patsjemoe
Postby Patsjemoe » Sat Aug 10, 2019 5:39 am
when I click on the IDF_PATH.sh in the profile.d directory, it opens a screen and says :
bash: c:/msys32/home/user/esp-idf-v3.2.2: is a directory
/usr/bin/bash: Exit 126.
so this does not work..therefore, no automatically created path...now to solve this...
WiFive
Postby WiFive » Sat Aug 10, 2019 6:02 am
The contents of IDF_PATH.sh file should be
export IDF_PATH="c:/msys32/home/user/esp-idf-v3.2.2"
Try running autorebase.bat in msys2 directory
Users browsing this forum: MSN [Bot] and 21 guests
