CMake include extra components
gibson12345
Postby gibson12345 » Tue Aug 27, 2019 5:05 am
Hey everyone,
I'm trying to include an extra library that interfaces with an accelerometer and I'm not quite understanding how to include it as an extra component.
My dir structure looks like this
- project/
             - CMakeLists.txt
             - sdkconfig
             - components/
                           - Lib1/
                                         - CMakeLists.txt
                                         - src1.c
                                         - src1.h
                           - Lib2/
                                         - CMakeLists.txt
                                         - src1.c
                                         - src2.h
             - main/
                           - main.c
                           - accel.c
                           - accel.h
                           - CMakeLists.txt
What do I need to change in my top level CMakeLists.txt and add to the ones inside the components themselves
Cheers,
Gibson
ESP_Angus
Re: CMake include extra components
Postby ESP_Angus » Tue Aug 27, 2019 11:41 pm
Hi Gibson,
(Reply assumes your using ESP-IDF V4.x or current master branch, if you're using v3.x then some of the specifics are a little different.)
Provided "Lib1" and "Lib2" have CMakeLists.txt files that call "idf_component_register", they should be added to the build already. You can check they're in the list of components shown in the log when CMake runs (or when "idf.py reconfigure" runs).
How exactly does it fail at the moment?
If it's a failure to include headers between components, it may be because CMake-based components have to declare their dependencies. So if Lib1 depends on Lib2 (or vice versa) then Lib1 will need to pass "REQUIRES Lib2" or "PRIV_REQUIRES Lib2" in "idf_component_register". You can about these in the docs:
https://docs.espressif.com/projects/esp ... quirements
gibson12345
Postby gibson12345 » Tue Aug 27, 2019 11:54 pm
Hey Angus,
You are correct I am operating in the 4.0 branch
It seems to be failing on this:
ninja: no work to do.
[2/11] Building C object esp-idf/lis3dh/CMakeFiles/__idf_lis3dh.dir/lis3dh.c.obj
FAILED: esp-idf/lis3dh/CMakeFiles/__idf_lis3dh.dir/lis3dh.c.obj
C:\Users\lachlan\.espressif\tools\xtensa-esp32-elf\esp32-2019r1-8.2.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -Iconfig -IC:/esp/esp-idf/components/newlib/platform_include -IC:/esp/esp-idf/components/freertos/include -IC:/esp/esp-idf/components/heap/include -IC:/esp/esp-idf/components/log/include -IC:/esp/esp-idf/components/soc/esp32/include -IC:/esp/esp-idf/components/soc/include -IC:/esp/esp-idf/components/esp_rom/include -IC:/esp/esp-idf/components/esp_common/include -IC:/esp/esp-idf/co
mponents/xtensa/include -IC:/esp/esp-idf/components/xtensa/esp32/include -IC:/esp/esp-idf/components/esp32/include -IC:/esp/esp-idf/components/driver/include -IC:/esp/esp-idf/components/esp_ringbuf/include -IC:/esp/esp-idf/components/esp_event/include -IC:/esp/esp-idf/components/tcpip_adapter/include -IC:/esp/esp-idf/components/lwip/include/apps -IC:/esp/esp-idf/components/lwip/include/apps/sntp -IC:/esp/esp-idf/components/lwip/lwip/src/include -IC:/esp/esp-idf/components/lwip/port/esp32/include
-IC:/esp/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp/esp-idf/components/vfs/include -IC:/esp/esp-idf/components/esp_wifi/include -IC:/esp/esp-idf/components/esp_wifi/esp32/include -IC:/esp/esp-idf/components/esp_eth/include -IC:/esp/esp-idf/components/efuse/include -IC:/esp/esp-idf/components/efuse/esp32/include -IC:/esp/esp-idf/components/app_trace/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -nostdlib -Wall -Werror=all -
Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.0-dev-1443-g39f090a4f-dirty\" -DGCC_NOT_5_2_0 -DESP_PLATFORM -MD -MT esp-idf/lis3dh/CMakeFiles/__idf_lis3dh.dir/lis3dh.c.obj -MF esp-idf\lis3dh\CMakeFiles\__idf_lis3dh.dir\lis3dh.c.obj.d -o esp-idf/lis3dh/CMakeFiles/__idf_lis3dh.dir/lis3dh.c.obj -c .
./components/lis3dh/lis3dh.c
In file included from ../components/lis3dh/lis3dh.h:94,
from ../components/lis3dh/lis3dh.c:53:
../components/lis3dh/lis3dh_platform.h:52:10: fatal error: esp8266_wrapper.h: No such file or directory
#include "esp8266_wrapper.h"
compilation terminated.
[3/11] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/accelerometer.c.obj
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/accelerometer.c.obj
C:\Users\lachlan\.espressif\tools\xtensa-esp32-elf\esp32-2019r1-8.2.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -Iconfig -I../main/. -IC:/esp/esp-idf/components/newlib/platform_include -IC:/esp/esp-idf/components/freertos/include -IC:/esp/esp-idf/components/heap/include -IC:/esp/esp-idf/components/log/include -IC:/esp/esp-idf/components/soc/esp32/include -IC:/esp/esp-idf/components/soc/includ
e -IC:/esp/esp-idf/components/esp_rom/include -IC:/esp/esp-idf/components/esp_common/include -IC:/esp/esp-idf/components/xtensa/include -IC:/esp/esp-idf/components/xtensa/esp32/include -IC:/esp/esp-idf/components/esp32/include -IC:/esp/esp-idf/components/driver/include -IC:/esp/esp-idf/components/esp_ringbuf/include -IC:/esp/esp-idf/components/esp_event/include -IC:/esp/esp-idf/components/tcpip_adapter/include -IC:/esp/esp-idf/components/lwip/include/apps -IC:/esp/esp-idf/components/lwip/include
/apps/sntp -IC:/esp/esp-idf/components/lwip/lwip/src/include -IC:/esp/esp-idf/components/lwip/port/esp32/include -IC:/esp/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp/esp-idf/components/vfs/include -IC:/esp/esp-idf/components/esp_wifi/include -IC:/esp/esp-idf/components/esp_wifi/esp32/include -IC:/esp/esp-idf/components/esp_eth/include -IC:/esp/esp-idf/components/efuse/include -IC:/esp/esp-idf/components/efuse/esp32/include -IC:/esp/esp-idf/components/app_trace/include -IC:/esp/esp-i
df/components/mbedtls/port/include -IC:/esp/esp-idf/components/mbedtls/mbedtls/include -IC:/esp/esp-idf/components/wpa_supplicant/include -IC:/esp/esp-idf/components/wpa_supplicant/port/include -IC:/esp/esp-idf/components/wpa_supplicant/include/esp_supplicant -IC:/esp/esp-idf/components/bootloader_support/include -IC:/esp/esp-idf/components/app_update/include -IC:/esp/esp-idf/components/spi_flash/include -IC:/esp/esp-idf/components/nvs_flash/include -IC:/esp/esp-idf/components/smartconfig_ack/in
clude -IC:/esp/esp-idf/components/pthread/include -IC:/esp/esp-idf/components/espcoredump/include -IC:/esp/esp-idf/components/asio/asio/asio/include -IC:/esp/esp-idf/components/asio/port/include -IC:/esp/esp-idf/components/bt/include -IC:/esp/esp-idf/components/bt/common/osi/include -IC:/esp/esp-idf/components/bt/host/bluedroid/api/include/api -IC:/esp/esp-idf/components/coap/port/include -IC:/esp/esp-idf/components/coap/port/include/coap -IC:/esp/esp-idf/components/coap/libcoap/include -IC:/esp
/esp-idf/components/coap/libcoap/include/coap2 -IC:/esp/esp-idf/components/console/. -IC:/esp/esp-idf/components/nghttp/port/include -IC:/esp/esp-idf/components/nghttp/nghttp2/lib/includes -IC:/esp/esp-idf/components/esp-tls/. -IC:/esp/esp-idf/components/esp-tls/PRIVATE_INCLUDE_DIRS -IC:/esp/esp-idf/components/esp-tls/private_include -IC:/esp/esp-idf/components/esp_adc_cal/include -IC:/esp/esp-idf/components/esp_gdbstub/include -IC:/esp/esp-idf/components/tcp_transport/include -IC:/esp/esp-idf/c
omponents/tcp_transport/PRIVATE_INCLUDE_DIRS -IC:/esp/esp-idf/components/tcp_transport/private_include -IC:/esp/esp-idf/components/esp_http_client/include -IC:/esp/esp-idf/components/esp_http_server/include -IC:/esp/esp-idf/components/esp_https_ota/include -IC:/esp/esp-idf/components/protobuf-c/protobuf-c -IC:/esp/esp-idf/components/protocomm/include/common -IC:/esp/esp-idf/components/protocomm/include/security -IC:/esp/esp-idf/components/protocomm/include/transports -IC:/esp/esp-idf/components/
mdns/include -IC:/esp/esp-idf/components/esp_local_ctrl/include -IC:/esp/esp-idf/components/esp_websocket_client/include -IC:/esp/esp-idf/components/expat/expat/expat/lib -IC:/esp/esp-idf/components/expat/port/include -IC:/esp/esp-idf/components/wear_levelling/include -IC:/esp/esp-idf/components/sdmmc/include -IC:/esp/esp-idf/components/fatfs/diskio -IC:/esp/esp-idf/components/fatfs/vfs -IC:/esp/esp-idf/components/fatfs/src -IC:/esp/esp-idf/components/freemodbus/common/include -IC:/esp/esp-idf/c
omponents/idf_test/include -IC:/esp/esp-idf/components/jsmn/include -IC:/esp/esp-idf/components/json/cJSON -IC:/esp/esp-idf/components/libsodium/libsodium/src/libsodium/include -IC:/esp/esp-idf/components/libsodium/port_include -IC:/esp/esp-idf/components/mqtt/esp-mqtt/include -IC:/esp/esp-idf/components/openssl/include -IC:/esp/esp-idf/components/spiffs/include -IC:/esp/esp-idf/components/ulp/include -IC:/esp/esp-idf/components/unity/include -IC:/esp/esp-idf/components/unity/unity/src -IC:/esp/
esp-idf/components/wifi_provisioning/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -nostdlib -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.0-dev-1443-g39f090a4f-dirty\" -DGCC_NOT_5_2_0 -DESP_PLATFORM -MD -MT esp-idf/main
/CMakeFiles/__idf_main.dir/accelerometer.c.obj -MF esp-idf\main\CMakeFiles\__idf_main.dir\accelerometer.c.obj.d -o esp-idf/main/CMakeFiles/__idf_main.dir/accelerometer.c.obj -c ../main/accelerometer.c
In file included from ../main/accelerometer.c:1:
../main/accelerometer.h:6:10: fatal error: lis3dh.h: No such file or directory
#include "lis3dh.h"
So it's failing to locate the actual headers for the library. I've tried reading over that documentation but it's rather vague and unclear to me, but that's likely just my inexperience with CMake. My components do use idf_component_register but don't use any require but I'm unsure if that's the issue it may be for the first error. Looking at it now I don't think it's necessarily an issue with including them as a component because they're shown in the list of components when I try to compile
Cheers,
Gibson
gibson12345
Postby gibson12345 » Fri Aug 30, 2019 3:42 am
Hey @Angus,
Any suggestions I'm sort of lost on this one.
Cheers,
Gibson
ESP_Angus
Postby ESP_Angus » Fri Aug 30, 2019 7:07 am
Hi Gibson,
Sorry for the delay in getting back to you.
For this to work the component "lis3dh" needs to declare that it REQUIRES the component that contains the esp8266_wrapper.h header. Here's an example of how this looks when registering the component in ESP-IDF V4.0:
https://github.com/espressif/esp-idf/bl ... sts.txt#L4
Also, the component that contains esp8266_wrapper.h must have that directory in its INCLUDE_DIRS list so that the build system knows there are headers in there.
 #include "lis3dh.h"
This one is different because the "main" component automatically sees all the components in the project, so you don't need to give a REQUIRES list for "main" component.
Suggest checking that the component that provides "lis3dh.h" has this directory in its INCLUDE_DIRS list in CMakeLists.txt
If you're still stuck and it's not working, is it possible to give us the full contents of the relevant CMakeLists.txt files?
gibson12345
Postby gibson12345 » Sun Sep 01, 2019 11:23 pm
Hi Gibson,
All good I understand you're likely busy especially if you are still having internal CI issues.
Okay I'm not quite sure I understand that second part fully but here is what my CMakeLists.txt look like now
esp8266 component
idf_component_register(SRCS "esp8266_wrapper.c"
                       INCLUDE_DIRS "../lis3dh")
lis3dh component
idf_component_register(SRCS "lis3dh.c"
                       REQUIRES esp8266)
This one I also don't fully understand but here is my CMakeLists.txt for my main component.
set(COMPONENT_REQUIRES )
set(COMPONENT_PRIV_REQUIRES )
set(COMPONENT_SRCS  "main.c"
                    "talkiplayer.c"
                    "bluetooth.c"
                    "nfc.c"
                    "soundPlayer.c"
                    "powerManagement.c"
                    "inactivityTimer.c"
                    "accelerometer.c")
set(COMPONENT_ADD_INCLUDEDIRS ".")
register_component()
And just incase you need it here it my top level CMakeLists.txt
cmake_minimum_required(VERSION 3.5)
project(SourceCode)
Thanks a lot for you consistent help :)
Cheers,
Gibson
ESP_Angus
Postby ESP_Angus » Mon Sep 02, 2019 1:57 am
Hi Gibson,
I think the problem is here:
esp8266 component
INCLUDE_DIRS should be a list of the public header directories that are part of this component. So if esp8266 component also contains esp8266_wrapper.h then the directory contianing that headers needs to be listed here, not the directory that belongs to the other component.
This way when the lis3dh component says that it "REQUIRES esp8266", the build system says "OK, what header directories does this mean I now include" and see the list of INCLUDE_DIRS from the esp8266 component. Which means that "#include "esp8266_wrapper.h" will work when compiling lis3dh source files.
Does that makes sense?
gibson12345
Postby gibson12345 » Mon Sep 02, 2019 4:22 am
Hey Angus,
I'm not quite sure I get what you mean for this but would that mean if all of the header files are self contained inside the component folder the include_dir would just need to be "." ??
And would this then mean that so my "Main" component recognises the lis3dh.h header I could need to also have an include_dir of "."?
Tbh I'm not quite sure I understand so correct me if I'm wrong about this.
Thanks again for your understanding in teaching me this :)
Cheers,
Gibson
ESP_Angus
Postby ESP_Angus » Mon Sep 02, 2019 5:15 am
Correct!
(Some components have an "include" directory for the public headers and some private headers in "." which is why we don't assume that "." is where the public headers live, the component tells the build system instead.)
An INCLUDE_DIR of "." in the lis3dh.h component? Yes, that's right (if that's where the header lives).
"main" component is special because it is assumed to REQUIRE all the components in the project without needing to specify this (the assumption being this is where you'll initialise all the other components in the project.)
gibson12345
Postby gibson12345 » Mon Sep 02, 2019 5:41 am
Correct!
Thanks a bunch angus! Managed to get it working after my last post and have been fiddling since. Maybe I'm just unfamiliar and still learning but the documentation on adding components etc in the new build system was a little confusing is there plans to make it a bit more verbose in the future?
Cheers,
Gibson
Users browsing this forum: Google [Bot] and 171 guests
