PPP does not detect modem disconnection
vinimac
Postby vinimac » Thu Nov 07, 2019 4:49 pm
Hi all,
I am simulating a signal loss by removing the antenna from the modem and I keep sending packets to a server using TCP socket. After remove the antenna, the function lwip_send() wont fail and error number is not set too.
I was expecting TCP layer to detect the lack of TCP ACK or PPP should have some timeout?
I am running Lwip 2.0 from ESP32 SDK .
commit 3bf56cdd178e8b237121a8fa07862f484db68541
Merge: ba51e9fb5 d41d70b8e
Author: Angus Gratton <angus@espressif.com>
Date: Tue May 21 14:56:34 2019 +0800
gunar.kroeger
Re: PPP does not detect modem disconnection
Postby gunar.kroeger » Fri Nov 08, 2019 8:10 pm
We see this issue on esp-idf-v3.3 aswell.
there are a few issues opened on github regarding pppos disconnection and reconnection problems but no official answer yet /:
https://github.com/espressif/esp-idf/is ... 3Aopen+ppp
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
vinimac
Postby vinimac » Thu Nov 28, 2019 5:31 pm
PPP might detect connection loss, but TCP won't. That's expected, unless
you use LWIP_TCP_KEEPALIVE (just gxxxle for tcp keepalive...).
Regards,
Simon
http://lwip.100.n7.nabble.com/PPPos-doe ... 35008.html
Users browsing this forum: Bing [Bot], MSN [Bot], rillhu and 21 guests
