Help debugging ESP32 WROOM with jlink edu mini
Posted: Fri Nov 08, 2019 6:25 pm
by PaulELong
I'm trying to setup a debugging, but OpenOCD fails to connect and repeats the warning "Failed to receive data from device: LIBUSB_ERROR_TIMEOUT." Then I see Error: Sending data to device timed out. I'll put the full output below.
The steps I remember that I took to get here are:
1. Installed driver for jlink edu mini
2. Ran jlink.exe, it prompted me to update firmware, which I did.
3. Ran USB Driver Tool to set at WinUSB
4. Ran OpenOCD (see below)
I found on the web that someone else mentioned issues with jlink edu mini, so I'm wondering if it works? And if not, why doesn't it work, like who should I follow up with next?
Here's the log output
PS> openocd -f interface/jlink.cfg -f board/esp-wroom-32.cfg
Open On-Chip Debugger  v0.10.0-esp32-20190708 (2019-07-08-11:04)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Warn : Failed to receive data from device: LIBUSB_ERROR_TIMEOUT.
Info : J-Link EDU Mini V1 compiled Oct 22 2019 16:28:45
Info : Hardware version: 1.00
Warn : Failed to send data to device: LIBUSB_ERROR_TIMEOUT.
Error: transport_write() failed: timeout occurred.
Error: jaylink_get_hardware_status() failed: timeout occurred.
Warn : Flash driver of esp32.flash does not support free_driver_priv()
Warn : Flash driver of irom does not support free_driver_priv()
Warn : Flash driver of drom does not support free_driver_priv()
Thanks -Paul
Re: Help debugging ESP32 WROOM with jlink edu mini
Posted: Tue Nov 19, 2019 10:03 pm
by PaulELong
I determined I made a stupid mistake, though debugging with jlink edu mini is not working yet. The first problem is that I had the cable backwards. I picture I found showed it connected incorrectly which I now found is backwards. I see that it connects, but now it's getting timeout errors. I do see another similar complaint with no solution, so perhaps OpenOCD doens't support the jlink edu mini.
If somebody has this working, I would like to hear about it.
This is my log now
adapter speed: 1000 kHz
Info : VTarget = 3.292 V
Info : clock speed 1000 kHz
Info : Detected debug stubs @ 3ffb2980 on core0 of target 'esp32'
Error: No symbols for FreeRTOS
Error: jaylink_jtag_io() failed: timeout occurred.
Error: Failed to fetch AR regs!
