ESP IDF installation error: Unexpected end of archive
Spero1
Postby Spero1 » Wed Dec 04, 2019 11:42 pm
Hi there,
I'm trying to install esp-idf-tools-setup-2.1.exe on my Windows 10, 64-bit PC running as Administrator.
During the installation process I get the following error and cannot continue:
Path = C:\Users\Spero-Colyvas\.espressif\releases\esp-idf-v3.3.zip
Type = zip
ERRORS:
Physical Size = 192052138
Characteristics = Local
Has anyone seen this before - any ideas what the problem could be?
Thanks,
Spero
wrybread
Re: ESP IDF installation error: Unexpected end of archive
Postby wrybread » Thu Feb 06, 2020 11:36 pm
I'm getting the same error. Did you ever solve it?
ESP_Angus
Postby ESP_Angus » Fri Feb 07, 2020 3:53 am
The installer doesn't include any ESP-IDF versions, but it can optionally download ESP-IDF as part of the install - it looks like that's what it was doing in this case.
It looks like maybe the download failed part way through, "PhysicalSize = 192052138" is smaller than the 350MB size of this zip file.
It's possible we can do something in the installer to better detect download failures, but in the meantime I'd recommend trying again and seeing if the download succeeds the second time. If it still doesn't work then it's possible to skip this step in the installer and then download ESP-IDF from the Releases page on GitHub: https://github.com/espressif/esp-idf/releases/
Angus
wrybread
Postby wrybread » Fri Feb 07, 2020 4:04 am
I think there might be something wrong with the linked version? I tried several times with the current version but it failed every time. When I selected the previous version it worked right away.
Users browsing this forum: Bing [Bot] and 16 guests
