CORE DUMP:
==================== ESP32 CORE DUMP START ====================
================== CURRENT THREAD REGISTERS ===================
pc 0x40084c91 0x40084c91 <esp_timer_impl_set_alarm+345>
lbeg 0x4000c2e0 1073791712
lend 0x4000c2f6 1073791734
lcount 0xffffffff 4294967295
sar 0x4 4
ps 0x60624 394788
threadptr <unavailable>
br <unavailable>
scompare1 <unavailable>
acclo <unavailable>
acchi <unavailable>
m0 <unavailable>
m1 <unavailable>
m2 <unavailable>
m3 <unavailable>
expstate <unavailable>
f64r_lo <unavailable>
f64r_hi <unavailable>
f64s <unavailable>
fcr <unavailable>
fsr <unavailable>
a0 0x40081dc6 1074273734
a1 0x3ffaf9a0 1073412512
a2 0x86000264 -2046819740
a3 0x4 4
a4 0x86009d8c -2046780020
a5 0x86000264 -2046819740
a6 0x82fffe7f -2097152385
a7 0x4 4
a8 0xefffffff -268435457
a9 0x3ff47024 1072984100
a10 0xeffffffe -268435458
a11 0xa0 160
a12 0x30003e5 50332645
a13 0xf0013790 -268355696
a14 0x60620 394784
a15 0x60023 393251
==================== CURRENT THREAD STACK =====================
#0 0x40084c91 in esp_timer_impl_set_alarm (timestamp=19428016740) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/esp_timer_esp32.c:239
#1 0x40081dc6 in timer_insert (timer=0x3ffc1844) at C:/msys32/home/anonymous/esp/esp-idf/components/esp_common/src/esp_timer.c:204
#2 0x400d3934 in timer_process_alarm (dispatch_method=<optimized out>) at C:/msys32/home/anonymous/esp/esp-idf/components/esp_common/src/esp_timer.c:284
#3 0x400d39b6 in timer_task (arg=0x0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp_common/src/esp_timer.c:316
#4 0x40090758 in vPortTaskWrapper (pxCode=0x400d398c <timer_task>, pvParameters=0x0) at C:/msys32/home/anonymous/esp/esp-idf/components/freertos/port.c:143
======================== THREADS INFO =========================
Id Target Id Frame
* 1 <main task> 0x40084c91 in esp_timer_impl_set_alarm (timestamp=19428016740) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/esp_timer_esp32.c:239
2 process 1 0x4017146e in esp_pm_impl_waiti () at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/pm_esp32.c:484
3 process 2 0x4017146e in esp_pm_impl_waiti () at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/pm_esp32.c:484
4 process 3 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
5 process 4 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
6 process 5 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
7 process 6 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
8 process 7 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
9 process 8 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
10 process 9 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
11 process 10 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
12 process 11 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
13 process 12 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
14 process 13 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
15 process 14 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
16 process 15 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
17 process 16 xEventGroupWaitBits (xEventGroup=0x3ffd27f8, uxBitsToWaitFor=3, xClearOnExit=0, xWaitForAllBits=0, xTicksToWait=4294967295) at C:/msys32/home/anonymous/esp/esp-idf/components/freertos/event_groups.c:445
18 process 17 0x40091124 in xQueueGenericReceive (xQueue=0x3ffaff84, pvBuffer=0x0, xTicksToWait=<optimized out>, xJustPeeking=0) at C:/msys32/home/anonymous/esp/esp-idf/components/freertos/include/freertos/portable.h:214
19 process 18 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
20 process 19 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
21 process 20 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
======================= ALL MEMORY REGIONS ========================
Name Address Size Attrs
.rtc.text 0x400c0000 0x0 RW
.rtc.dummy 0x3ff80000 0x0 RW
.rtc.force_fast 0x3ff80000 0x0 RW
.rtc_noinit 0x50000000 0x0 RW
.rtc.force_slow 0x50000000 0x0 RW
.iram0.vectors 0x40080000 0x400 R XA
.iram0.text 0x40080400 0x12080 RWXA
.dram0.data 0x3ffb0000 0x36e8 RW A
.noinit 0x3ffb36e8 0x0 RW
.flash.rodata 0x3f400020 0x264ac RW A
.flash.text 0x400d0018 0xa3140 R XA
.coredump.tasks.data 0x3ffafab4 0x164 RW
.coredump.tasks.data 0x3ffaf8e0 0x1cc RW
.coredump.tasks.data 0x3ffc00a8 0x164 RW
.coredump.tasks.data 0x3ffbff00 0x1a0 RW
.coredump.tasks.data 0x3ffbf93c 0x164 RW
.coredump.tasks.data 0x3ffbf790 0x1a4 RW
.coredump.tasks.data 0x3ffc2168 0x164 RW
.coredump.tasks.data 0x3ffc1eb0 0x2b0 RW
.coredump.tasks.data 0x3ffc6084 0x164 RW
.coredump.tasks.data 0x3ffc5e50 0x22c RW
.coredump.tasks.data 0x3ffc41c8 0x164 RW
.coredump.tasks.data 0x3ffc4020 0x1a0 RW
.coredump.tasks.data 0x3ffc4720 0x164 RW
.coredump.tasks.data 0x3ffc4550 0x1c8 RW
.coredump.tasks.data 0x3ffc385c 0x164 RW
.coredump.tasks.data 0x3ffc35f0 0x264 RW
.coredump.tasks.data 0x3ffd40cc 0x164 RW
.coredump.tasks.data 0x3ffd3e80 0x244 RW
.coredump.tasks.data 0x3ffd2430 0x164 RW
.coredump.tasks.data 0x3ffd2250 0x1d8 RW
.coredump.tasks.data 0x3ffcdbd0 0x164 RW
.coredump.tasks.data 0x3ffcda00 0x1c8 RW
.coredump.tasks.data 0x3ffd4a38 0x164 RW
.coredump.tasks.data 0x3ffd4860 0x1d0 RW
.coredump.tasks.data 0x3ffbdb14 0x164 RW
.coredump.tasks.data 0x3ffc4f00 0x1c4 RW
.coredump.tasks.data 0x3ffc0b08 0x164 RW
.coredump.tasks.data 0x3ffc0940 0x1c0 RW
.coredump.tasks.data 0x3ffd1ac4 0x164 RW
.coredump.tasks.data 0x3ffd1740 0x37c RW
.coredump.tasks.data 0x3ffd0958 0x164 RW
.coredump.tasks.data 0x3ffd0570 0x3e0 RW
.coredump.tasks.data 0x3ffd6ba4 0x164 RW
.coredump.tasks.data 0x3ffd62b0 0x8ec RW
.coredump.tasks.data 0x3ffbd934 0x164 RW
.coredump.tasks.data 0x3ffbd780 0x1ac RW
.coredump.tasks.data 0x3ffc705c 0x164 RW
.coredump.tasks.data 0x3ffc6e50 0x204 RW
.coredump.tasks.data 0x3ffc8904 0x164 RW
.coredump.tasks.data 0x3ffc86f0 0x20c RW
.coredump.tasks.data 0x3ffafe1c 0x164 RW
.coredump.tasks.data 0x3ffbd360 0x1c8 RW
===================== ESP32 CORE DUMP END =====================
pc 0x40084c32 0x40084c32 <esp_timer_impl_set_alarm+250>
sar 0x4 4
ps 0x60924 395556
br <unavailable>
acclo <unavailable>
acchi <unavailable>
m0 <unavailable>
m1 <unavailable>
m2 <unavailable>
m3 <unavailable>
f64s <unavailable>
fcr <unavailable>
fsr <unavailable>
a2 0x5500031f 1426064159
a3 0x2 2
a4 0x5502fddf 1426259423
a5 0x5500031f 1426064159
a6 0x51ffff3a 1375731514
a7 0x2 2
a8 0x3ff47024 1072984100
a9 0xf16c1bed -244573203
a10 0x3ffb8178 1073447288
a11 0xa0 160
a14 0x60920 395552
a15 0x60023 393251
#0 0x40084c32 in esp_timer_impl_set_alarm (timestamp=10015998751) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/esp_timer_esp32.c:229
Id Target Id Frame
* 1 <main task> 0x40084c32 in esp_timer_impl_set_alarm (timestamp=10015998751) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/esp_timer_esp32.c:229
16 process 15 0x40091124 in xQueueGenericReceive (xQueue=0x3ffd26a4, pvBuffer=0x3ffd05f4, xTicksToWait=<optimized out>, xJustPeeking=0) at C:/msys32/home/anonymous/esp/esp-idf/components/freertos/include/freertos/portable.h:214
17 process 16 0x40081d20 in esp_crosscore_int_send_yield (core_id=0) at C:/msys32/home/anonymous/esp/esp-idf/components/esp32/crosscore_int.c:111
.coredump.tasks.data 0x3ffc5fb8 0x164 RW
.coredump.tasks.data 0x3ffc5d90 0x220 RW
.coredump.tasks.data 0x3ffd2364 0x164 RW
.coredump.tasks.data 0x3ffd2180 0x1dc RW
.coredump.tasks.data 0x3ffd408c 0x164 RW
.coredump.tasks.data 0x3ffd3e40 0x244 RW
.coredump.tasks.data 0x3ffcdb04 0x164 RW
.coredump.tasks.data 0x3ffcd930 0x1cc RW
.coredump.tasks.data 0x3ffd49f8 0x164 RW
.coredump.tasks.data 0x3ffd4820 0x1d0 RW
.coredump.tasks.data 0x3ffd19f8 0x164 RW
.coredump.tasks.data 0x3ffd1680 0x370 RW
.coredump.tasks.data 0x3ffd088c 0x164 RW
.coredump.tasks.data 0x3ffd04c0 0x3c4 RW
.coredump.tasks.data 0x3ffd6b64 0x164 RW
.coredump.tasks.data 0x3ffd6250 0x90c RW
.coredump.tasks.data 0x3ffc6f90 0x164 RW
.coredump.tasks.data 0x3ffc6d80 0x208 RW
.coredump.tasks.data 0x3ffc8838 0x164 RW
.coredump.tasks.data 0x3ffc8630 0x200 RW
How can I find out the reason for this behavior?
