efuse CHIP_PACKAGE different for WROOM-32U
plajjd
Postby plajjd » Tue Jan 14, 2020 8:20 pm
What is the CHIP_PACKAGE value in eFuse used for?
I have noticed that ESP32-WROOM-32U (with U.FL antenna connector) is value 1.
Whereas ESP32-WROOM-32D (PCB antenna) is value 0.
Is CHIP_PACKAGE an indicator of the package antenna connection?
Thanks!
Phil.
WiFive
Re: efuse CHIP_PACKAGE different for WROOM-32U
Postby WiFive » Wed Jan 15, 2020 10:30 am
Both D and U should use type 1 which is 5x5mm chip. Older wroom use type 0 which is 6x6mm chip. I don't think it is related to antenna.
plajjd
Postby plajjd » Wed Jan 15, 2020 4:20 pm
Thanks!
Do you know of any way to determine the antenna configuration (other than external observation and saving something manually in eFuse)?
Phil.
WiFive
Postby WiFive » Wed Jan 15, 2020 9:35 pm
No, I think you'd have to check the Mac address and be able to match it to a production batch assuming they are sequential.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 13 guests
