SD/MMC interface card capacity limits
datltq
Postby datltq » Wed Jan 15, 2020 6:37 am
In this example the card capacity showed
https://github.com/espressif/esp-idf/tr ... ge/sd_card. I assume this is a 64GB card. I'm not sure what is the maximum capacity supported by ESP-IDF
Is there any limits placed on SD/MMC cards using SPI interface supported on ESP-IDF? If yes, what is the limit?
Thank you all.
ESP_igrr
Re: SD/MMC interface card capacity limits
Postby ESP_igrr » Thu Jan 16, 2020 1:22 am
Typically for SDHC cards the size is limited by the filesystem, not the hardware. Cards larger than 32GB are typically sold formatted as exFat file system. FATFS library does support exFat, but this is not enabled by default. Also keep in mind that there are parents covering exFat which are still valid. So it is possible to support even larger cards, but whether you want to enable this in a product is a separate question.
Users browsing this forum: Baidu [Spider], MSN [Bot], WiFive and 43 guests
