Automatic / Periodic Flushing of Apptrace-based Logging
p-rimes
Postby p-rimes » Fri Jan 31, 2020 5:39 pm
I am trying to use apptrace/TRAX-based logging to replace the default UART-based logging for my application.
It seems to be working, if I add this early in my app_main function
esp_log_set_vprintf(esp_apptrace_vprintf);
However I must manually call
esp_apptrace_flush(ESP_APPTRACE_DEST_TRAX, 100000);
to flush the collected logs out of TRAX and into the logtrace_proc.py script.
I'd like to have the logs flushed automatically (ideally as fast as possible), so long as it is not worse than UART, performance-wise. Is there a way to configure that, or is there something I'm doing incorrectly that is preventing that?
ESP_Alexey
Re: Automatic / Periodic Flushing of Apptrace-based Logging
Postby ESP_Alexey » Mon Feb 03, 2020 10:07 am
Actually the data are flushed automatically when TRAX HW buffer (16KB) is filled. But to flush them as fast as possible you need to call
esp_apptrace_flush()
manually now. For now I would suggest to write your own vprintf-like function which will call
esp_apptrace_vprintf()
and
just after that. And register that function using
esp_log_set_vprintf(your_own_apptrace_vprintf);
p-rimes
Postby p-rimes » Wed Feb 12, 2020 6:07 pm
Works for me! Thanks for your suggestion.
Users browsing this forum: No registered users and 165 guests
