ESP32-PICO-D4 external SPRAM
chuledeco
Postby chuledeco » Thu Feb 13, 2020 3:32 pm
Hello and thanks in advance
I was trying to understand why I can't add my external PSRAM working with my ESP32-pico-d4 chip
I'm using ESP-IDF v4.0 with eclipse. My PSRAM chip is LY68L6400 and is connected as described below:
PSRAM ESP32-PICO-D4
CS IO17 (pin 27)
SCLK CLK (pin 31)
SIO0/SI SD0
SIO1/SO SD1
SIO2 SD2
SIO3 SD3
The CS is configured in the menuconfig
In the spiram_psram.c file I see the same configuration I have:
#define PSRAM_SPIQ_SD0_IO          7
#define PSRAM_SPID_SD1_IO          8
#define PSRAM_SPIWP_SD3_IO         10
#define PSRAM_SPIHD_SD2_IO         9
but after loading anything to the chip I get:
I (225) psram: This chip is ESP32-PICO
E (230) cpu_start: Failed to init external RAM!
abort() was called at PC 0x4008136e on core 0
My PSRAM chip is connected to the VDD_SDIO and the voltage is 3.3V (measured)
With my oscilloscope, I can see signals in all pins except SIO3
If anyone can help me a bit I'll be very thanked because I'm very stuck with that.
Thanks in advance, Julian
ESP_Vikram
Re: ESP32-PICO-D4 external SPRAM
Postby ESP_Vikram » Thu Feb 13, 2020 3:54 pm
Maybe not useful for you...
But, I had similar problem few months back.
Turns out I was using pin 9 for CLK.
Following change worked for me...
If you go to $IDF_PATH/components/esp32/spiram_psram.c
There is a define:
#define PICO_PSRAM_CLK_IO          6
I changed this to
#define PICO_PSRAM_CLK_IO          9
...and it worked.
Maybe similar change you are missing?
chuledeco
Postby chuledeco » Thu Feb 13, 2020 4:14 pm
There is a define:
I changed this to
...and it worked.
Hello Vikram, thanks for your answer
I have the PSRAM SCLK pin connected to the CLK pin of the ESP32-PICO-D4 which is number GPIO6. It seems in my case I'm using the default PICO_PSRAM_CLK_IO
Thanks again, Julian
chuledeco
Postby chuledeco » Fri Feb 14, 2020 9:39 am
There is a define:
I changed this to
...and it worked.
Can you Vikram please tell me if the rest of your pines was connected as I did?
Also, did you use IDF 4.0?
Finally, did you configure something else than turn on SPI RAM on the menuconfig and set the CS pin?
Thanks again
Users browsing this forum: Baidu [Spider] and 40 guests
