#define U1TXD 10
#define U1RXD 9
const int uart_num = UART_NUM_2;
const int uart_buffer_size = (1024 * 2);
gpio_pad_select_gpio(LED);
gpio_set_direction(LED, GPIO_MODE_OUTPUT);
TaskHandle_t ledHandle = NULL;
QueueHandle_t uart_queue;
void ledTask(void *pvParameters)
int led = 0;
for(;;)
ESP_LOGI("ledTask", "blink");
gpio_set_level(LED, !led);
led = !led;
vTaskDelay(100);
void UART_init()
// uart config
uart_config_t uart_config = {
.baud_rate = 9600,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE
ESP_ERROR_CHECK(uart_param_config(uart_num, &uart_config));
ESP_ERROR_CHECK(uart_set_pin(uart_num, U1TXD, U1RXD, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE));
ESP_ERROR_CHECK(uart_driver_install(uart_num, uart_buffer_size, uart_buffer_size, 10, &uart_queue, ESP_INTR_FLAG_LEVEL1));
xTaskCreate(ledTask, "led_task", 2048, NULL, configMAX_PRIORITIES , &ledHandle);
vTaskDelay(200);
UART_init();
Thanks in advance!!
