[Solved] CMAKE how to use typedef enum declared in component
gunar.kroeger
Postby gunar.kroeger » Wed Mar 04, 2020 1:01 pm
I have a component with a header file "include/Config.h" which declares:
typedef enum {
	HW_VERSION_UNDEFINED = 0,
	HW_VERSION_1,				//green PCB
	HW_VERSION_2,				//yellow PCB
	HW_VERSION_3,				//navy PCB
	HW_VERSIONS_SIZE,
}HW_Versions;
in main.c, I am including Config.h, with no compilation errors. But when I try to use the define
ESP_LOGI(TAG, "%d", HW_VERSION_UNDEFINED)
I get an error 'HW_VERSION_UNDEFINED' undeclared (first use in this function);
Should I add something to some CMakeLists.txt to make this variable declared?
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
username
Re: CMAKE how to use typedef enum declared in component
Postby username » Wed Mar 04, 2020 2:09 pm
That is because there is already a file config.h in the file system. Even though you rename it to Config.h (Capital "C") does not matter.
Renaming it to say "Config_mine.h" works for me.
gunar.kroeger
Postby gunar.kroeger » Wed Mar 04, 2020 5:01 pm
works for me as well! thanks
Users browsing this forum: Bing [Bot] and 16 guests
