esp-idf-tools-setup-2.2 has failed with exit code 1
I try to setup esp-idf-4.0
Installation has failed with exit code 1
- Setup Log 2020-03-04 #006.txt
- (40.41 KiB) Downloaded 488 times
- ESP_krzychb
- Contact:
Re: esp-idf-tools-setup-2.2 has failed with exit code 1
Hi brp80000,
1. Use https://dl.espressif.com/dl/esp-idf-tools-setup-2.3.exe
2. Let the installer download a fresh copy of ESP-IDF
The issue details are covered in https://github.com/espressif/esp-idf/issues/4744
esp-idf-v4.0 more dont work with eclipse?
- ESP_krzychb
- Contact:
It does work https://docs.espressif.com/projects/esp ... setup.htmlbrp80000 wrote:esp-idf-v4.0 more dont work with eclipse?
(this information has not been updated in v4.0 docs)
This does not work again at the first installation step. It seems that manufacturers do not want to sell and maintain their products. Very sad. Two days have already been lost to upgrade from esp-idf-v3. 2. 2 to esp-idf-v4.0
- lll.jpg (18.47 KiB) Viewed 8870 times
- rrr.jpg (220.54 KiB) Viewed 8885 times
We are very sorry for the inconvenience caused.
Looks like the issue is caused by the Eclipse version - Could you make sure you have got the Eclipse 2018-12 CDT and above
https://github.com/espressif/idf-eclips ... requisites
Please provide the eclipse environment information to check further on this. Please copy and paste the entire config information and attach here.
Help > About Eclipse >Installation Details > Configuration
Thank you , installing Eclipse 12-2018 helped. I was able to open my project from v3. 2. 2 But there are problems with include. Files are visible , but errors appear during compilation.
- ccc.jpg (82.5 KiB) Viewed 8759 times
And finally the final chord, after restarting the Eclipse nothing else works. It's probably time to go back to v3. 2. 2. At least through the ass, but everything worked.
- ccc1.jpg (40.01 KiB) Viewed 8748 times
Stable version 3.2.2 is waiting for me. V4 never again .
- ccc2.jpg (208.32 KiB) Viewed 8704 times
Users browsing this forum: No registered users and 231 guests
