parttool.py not working as documented??
gunar.kroeger
Postby gunar.kroeger » Wed Mar 18, 2020 12:39 pm
how do I correctly use the parttool.py to flash to ota_1 partition?
https://docs.espressif.com/projects/esp ... -interface
tells me that I need to follow this format:
# Write to partition 'factory' the contents of a file named 'factory.bin'
parttool.py --port "/dev/ttyUSB1" write_partition --partition-name=factory "factory.bin"
but I'm getting this error using idf 4.0 in VS Code Windows 10:
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
gunar.kroeger
Re: parttool.py not working as documented??
Postby gunar.kroeger » Thu Mar 19, 2020 12:53 pm
Has anyone used parttool in idf 4.0 yet?
willemmerson
Postby willemmerson » Fri Mar 20, 2020 1:57 pm
Use --input:
parttool.py --port "/dev/ttyUSB1" write_partition --partition-name=factory --input "factory.bin"
gunar.kroeger
Postby gunar.kroeger » Fri Mar 20, 2020 2:19 pm
Use --input:
Still not working unfortunately:
parttool error 2.png (51.87 KiB) Viewed 1303 times
willemmerson
Postby willemmerson » Fri Mar 20, 2020 2:37 pm
I have had similar problems with parttool.py, but they turned out to be hardware problems. That command certainly works for me on latest sdk but I'm using linux.
Basically all parttool.py is doing is calling esp_tool.py so just find out that command and run it directly and you will get better errors. You can see from the error it's calling esp_tool read_flash something something, it's probably trying to get the address of the partition you've specified.
If you know your partition table then you can just call esp_tool write_flash directly.
gunar.kroeger
Postby gunar.kroeger » Fri Mar 20, 2020 2:56 pm
ok we got it working calling esptool.py
But I guess we can conclude that parttool.py is indeed not working as described in the docs
Users browsing this forum: Bing [Bot] and 47 guests
