my board is ESP32 Wrover
So far i managed to connect the board to ESP-Prog via Jtag and set up usb / ftdi drivers so that openocd can connect. ESP Prog seems to be able to communicate with the board but i'm not able to start a debugging session. Could you help me to move forward? Below i'm including output from OpenOCD and also from the Eclipse debugger session
`Open On-Chip Debugger v0.10.0-esp32-20200309 (2020-03-09-11:51)
Licensed under GNU GPL v2
For bug reports, read
Info : Configured 2 cores
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32: Debug controller 0 was reset.
Info : esp32: Core 0 was reset.
Info : esp32: Debug controller 1 was reset.
Info : esp32: Core 1 was reset.
Error: No symbols for FreeRTOS
Info : Target halted. CPU0: PC=0x4007A4E9 (active)
Info : Target halted. CPU1: PC=0x400076E0
Error: timed out while waiting for target halted / 4 - 2
Info : cpu0: Target halted, PC=0x40090365, debug_reason=00000000
Error: xtensa_wait_algorithm: not halted 0, pc 0x40090365, ps 0x60025
Error: Failed to wait algorithm (-302)!
Error: Algorithm run failed (-302)!
Error: Failed to run flasher stub (-302)!
Warn : Failed to get flash mappings (-302)!
Error: Target is already running an algorithm
Error: Failed to start algorithm (-4)!
Error: Algorithm run failed (-4)!
Error: Failed to run flasher stub (-4)!
Error: Failed to probe flash, size 0 KB
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
and on the GDB side / Eclipse:
Unfortunately there are many things i dont understand,dont know and are not familiar with. Got stuck, i dont even know what to ask you about - can you please help me get the debug session to run? Will provide more details but you have to tell me what else to add.Error in final launch sequence:
Failed to execute MI command:
-target-select remote localhost:3333
Error message from debugger back end:
Remote replied unexpectedly to 'vMustReplyEmpty': timeout
RG
