code generation for gatts_attr_db
hansonite
Postby hansonite » Mon Mar 30, 2020 12:32 pm
currently I've to implement a esp_gatts_attr_db_t (service attr tab) with more than 100 attributes. You may understand that
coding that by hand is a lot of work, since we have the attributes specified in a spreadsheet.
The esp_gatts_attr_db_t is consumed by this function esp_err_tesp_ble_gatts_create_attr_tab
https://docs.espressif.com/projects/esp ... _t7uint8_t
Do you know a tool which support the code generation of the gatts_attr_db with service, characteristics and characteristic values?
Any hint is appreciated !
Thanks & BR
Hannes
Since nobody answered my question will I provide my solution.
I'm using Eclipse as IDE. In Eclipse you can create templates. So for every characteristic and descriptor code block did I create a template, which did speed up the development rapidly and also lowered the error rate.
Users browsing this forum: No registered users and 53 guests
