ESP Wrover KIT UART problem,Rx not working
Posted: Thu Apr 02, 2020 8:34 am
Hello everyone,
I use the sample code from the uart_echo example, exactly:
That works without problems on Pico KIT, but not on the Wrover. From the Wrover I only can read the logs, but not to write.
I am using IDF-v3.3 on Visual GDB. It installed the drivers automatically. The interesting thing is that I see only one COM port from it, which works for uploading via JTAG, debugging also works.
Thank you in advance.
#define ECHO_TEST_TXD (GPIO_NUM_1)
#define ECHO_TEST_RXD (GPIO_NUM_3)
#define ECHO_TEST_RTS (UART_PIN_NO_CHANGE)
#define ECHO_TEST_CTS (UART_PIN_NO_CHANGE)
#define BUF_SIZE (256)
#define RESP_SIZE (128)
void main()
uart_config_t uart_config = {
.baud_rate = 115200,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_DISABLE,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE
uart_driver_install(UART_NUM_0, BUF_SIZE * 2, 0, 0, NULL, 0);
uart_param_config(UART_NUM_0, &uart_config);
uart_set_pin(UART_NUM_0, ECHO_TEST_TXD, ECHO_TEST_RXD, ECHO_TEST_RTS, ECHO_TEST_CTS);
