Hi all,
I wrote a simple c code http server using the socket-api/lwip, to send camera image data to a client (firefox browser after a request of corse).
Response header:
char *response="HTTP/1.1 200 OK\r\nContent-Type: image/jpeg\r\nContent-Length: 50880\r\nContent-Disposition: inline; filename=capture.jpg\r\nAccess-Control-Allow-Origin: *\r\n\r\n";
send(socket, response, strlen(response),0);// this goes out fast
THEN, i send the image data in a a second send transaction.
send(socket, pbuf, 50880, 0);//the image data is sent. this takes ages from 10 seconds to 1 minute, before function returns.
After send returns, the image starts displaying in the browser.
I am actually sending the complete response in two send() transactions.
I understand, that splitting the response in several send() transactions will still be "one" TCP response.
I am wondering if i did not meet any specific http protocol standards that causes the client to ..? wait for something else?
any clues?
HTTP response with payload via socket send() very slow
Re: HTTP response with payload via socket send() very slow
Actually, i am using an ethernet adapter, not wifi.
(I did use the iperf example earlier and got around 58Mb network speed, not too bad.)
Now I build in some debug print into emac_main.c.
Here is a log showing how packets of size 1490 Bytes are transmitted over ethernet.
Also they show the timestamps in milliseconds, when they happen.
So you can see how long it take to transmit 50KB. (25 seconds in this case)
Something is not right, i dont know what?!
***log eth send:
sending data...
lwip_send(55, data=0x3ffcacc8, size=47139, flags=0x0)
I (40267) emac: tx netif>1490
I (40267) emac: <tx done
I (40457) emac: tx netif>1490
I (40457) emac: <tx done
I (41507) emac: tx netif>1490
I (41507) emac: <tx done
I (41517) emac: tx netif>1490
I (41517) emac: <tx done
I (41527) emac: <tx done
I (43007) emac: tx netif>1490
I (43007) emac: <tx done
I (44507) emac: tx netif>1490
I (44507) emac: <tx done
I (44517) emac: <tx done
I (44517) emac: tx netif>1490
I (44527) emac: <tx done
I (44527) emac: tx netif>1490
I (44537) emac: tx netif>1490
I (44537) emac: <tx done
I (44547) emac: <tx done
I (44547) emac: tx netif>1490
I (44557) emac: tx netif>1490
I (44557) emac: <tx done
I (46007) emac: tx netif>1490
I (46007) emac: <tx done
I (49007) emac: tx netif>1490
I (49007) emac: <tx done
I (49017) emac: tx netif>1490
I (49017) emac: <tx done
I (49027) emac: <tx done
I (49027) emac: tx netif>1490
I (49037) emac: tx netif>1490
I (49037) emac: <tx done
I (50507) emac: tx netif>1490
I (50507) emac: <tx done
I (53507) emac: tx netif>1490
I (53507) emac: <tx done
I (59027) emac: tx netif>54
I (59027) emac: <tx done
I (59507) emac: tx netif>1490
I (59507) emac: <tx done
I (60367) emac: tx netif>42
I (60367) emac: <tx done
I (61007) emac: tx netif>1490
I (61007) emac: <tx done
I (62507) emac: tx netif>1490
I (62507) emac: <tx done
I (62517) emac: <tx done
I (62517) emac: tx netif>1490
I (62527) emac: <tx done
I (62527) emac: tx netif>1490
I (62537) emac: tx netif>1490
I (62537) emac: <tx done
lwip_send(55) err=0 written=47139
I (62547) emac: <tx done
I (62547) emac: tx netif>1490
I (62557) emac: <tx done
I (62557) emac: tx netif>1490
End of Transaction 3 <<<<<<<<<<<<<<<<<<<<<<<<
lwip_recvfrom(55, 0x3ffb8410, 400, 0x0, ..)
lwip_recvfrom: top while sock->lastdata=0x0
I (64007) emac: tx netif>1490
I (64007) emac: <tx done
I (65507) emac: tx netif>1490
I (65507) emac: <tx done
I (65707) emac: tx netif>1241
I (65707) emac: <tx done
I (65707) emac: tx netif>54
lwip_recvfrom: netconn_recv err=-15, netbuf=0x0
lwip_recvfrom(55): buf == NULL, error is "Connection closed."!
read failed!
Connection closed
lwip_close(55)
***log eth send:
sending data...
read failed!
Connection closed
lwip_close(55)
Hey!
Any progress here?
i am lso facing something similar.. Though, I use simultaneously: 1) http server based on IDF ESP HTTP server, and 2) custom outgoing requests using lwip socket.
Maybe mixing this isn't good?
Also, I don't see CPU overloads - my IDLE tasks take around 90% time.
Any progress here?
Users browsing this forum: No registered users and 110 guests
