Allocated memory in RTC
Dav_FR
Postby Dav_FR » Mon Mar 27, 2017 8:37 am
After read some post and documentation I think the response is no, but a sentence in the documentation let me an open doubt, so I have to ask.
It's possible allocate memory which will remain unchanged after deep sleep state?
At http://esp-idf.readthedocs.io/en/latest ... -stub.html is specified that strings must be declared array and RTC_RODATA_ATTR, but later, a sentence about the use of "rtc_wake_stub" as file prefix makes me doubt: "The second way is a better option if you need to use strings, or write other more complex code"
I checked with this small example to confirm the behaviour, but now I'm not sure if this is due to a bug when using "rtc_wake_stub" file prefix.
char * test1 = NULL;
int wake_count = 0;
void RTC_IRAM_ATTR esp_wake_deep_sleep(void) {
    esp_default_wake_deep_sleep();
    wake_count++;
void app_main(void)
	if (wake_count==0) {
		test1 = (char *) pvPortMallocCaps(32, MALLOC_CAP_8BIT);
		memset(test1,0,32);
		memcpy(test1,"esp32",5);
		ESP_LOGI(tagg,"First time! %d - %s",wake_count,test1);
	} else {
		ESP_LOGI(tagg,"Not First time! %d",wake_count);
		ESP_LOGI(tagg,"String val: %s",test1);
	ESP_LOGI(tagg,"Going to sleep");
	esp_deep_sleep(5*1000000);
Btw, there is other option which I missed?
Best regards and sorry for the incovenience,
Dav
ESP_igrr
Re: Allocated memory in RTC
Postby ESP_igrr » Mon Mar 27, 2017 9:10 am
It is not possible to do dynamic allocation in RTC memory, but you can do static (compile-time) allocation.
If you define a global variable with RTC_DATA_ATTR attribute, the variable will be placed into RTC_SLOW_MEM memory. You can see how this is done in sntp example:
https://github.com/espressif/esp-idf/bl ... main.c#L49
Dav_FR
Postby Dav_FR » Mon Mar 27, 2017 9:22 am
Hi Igrr,
Thanks your for the fast response, my idea is avoid the loss of complex structures (which contains allocated pointers, lists of allocated structs, ...) between deep sleeps.
So, I guess there are two solutions for me:
- Create a fixed structure declared as RTC_DATA_ATTR and "copy" the dynamic memory to this structure before deep sleep to recover this into dynamic memory after wake up.
- Use non volatile memory, which is my last option.
I guess RTC_DATA_ATTR is applied to structs without problems.
Thanks you again,
Dav
ESP_igrr
Postby ESP_igrr » Mon Mar 27, 2017 2:26 pm
Yes, you should be able to use RTC_DATA_ATTR with struct instances.
martinayotte
Postby martinayotte » Mon Mar 27, 2017 5:06 pm
Be aware that your structure can't hold pointers, but you need to have those arrays directly into the structures.
Dav_FR
Postby Dav_FR » Tue Mar 28, 2017 10:31 am
Sure, the problem I'm facing now is the lack of space in the RTC memory :(
Users browsing this forum: Baidu [Spider], Hello1024, HitecSmartHome and 269 guests
